arduino uno clone with wiznet ethernet problem
I purchased an arduino uno clone from china (ATmega328 , and the USB-to-serial converter chip is Atmega8U2) and a wiznet w5100 ethernet shield from ebay. I’m not able to ping my device and I’m sure my network settings are correct. I found a topic here on the forum dealing with the same issues as I do. here is a link to that topic http://arduino.cc/forum/index.php/topic,72566.75.html. it appeared that the problem was the arduino board (freeduino) and replacing it with an other uno resolved the problem.
so now my question… I uploaded the sketch below with these results:
A) arduino + ethernetshield → led 13 not blinking
B) arduino with no shield → led 13 not blinking
c) if I comment out Ethernet.begin(mac, ip, gateway, subnet) led 13 on the uno board is blinking as expected.
I have read that led 13 must blink in case A and B (although a little dimmer in case A). Is this correct? and can I conclude that my arduino uno clone has a defect based on these findings? or can I try something else?
I’m using arduino 1
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { 0x90, 0xA2, 0xDA, 0x00, 0x59, 0x67 };
byte ip[] = { 192, 168, 0, 2 };
byte gateway[] = { 192, 168, 0, 1 };
byte subnet[] = { 255, 255, 255, 0 };
  Ethernet.begin(mac, ip, gateway, subnet);
  pinMode(13,OUTPUT);
  digitalWrite(13,HIGH);
  digitalWrite(13,LOW);
any help is appreciated!
peace
Have you tried that code without the shield and no Ethernet.begin() in the sketch?
And the V1.0 Ethernet.begin() is different than what you are using. The V1.0 requires a dns server ip in there. I have found that if you don't use dns, it really doesn't matter what ip you give it.
Here are the choices for a static ip assignment. Note after just an IP, all else require a dns ip:
void begin(uint8_t *mac_address, IPAddress local_ip);
void begin(uint8_t *mac_address, IPAddress local_ip, IPAddress dns_server);
void begin(uint8_t *mac_address, IPAddress local_ip, IPAddress dns_server, IPAddress gateway);
void begin(uint8_t *mac_address, IPAddress local_ip, IPAddress dns_server, IPAddress gateway, IPAddress subnet);
Ping first.
yes I did, read A B C cases in my first post for the blink blink results :slight_smile: if I comment out ethernet.begin the led is blinking.
And the V1.0 Ethernet.begin() is different than what you are using. The V1.0 requires a dns server ip in there. I have found that if you don’t use dns, it really doesn’t matter what ip you give it.
I tried adding a dns in the Ethernet.begin function but cant ping the arduino and no blink blink
#include <SPI.h>
byte dns[] = { 195,130,130,4 };
  Ethernet.begin(mac, ip,dns, gateway, subnet);
  pinMode(13,OUTPUT);
Is there a dhcp server on that localnet? If so, try this:
#include <SPI.h>
  // Get ip from dhcp server.
  if(Ethernet.begin(mac)) Serial.println("dhcp ok");
  else Serial.println("No dhcp");
yes there is dhcp on my wireless d-link dir-615 router (range 192.168.0.100 - 192.168.0.199). my arduino is connected with a cable to the Ethernet port. my laptop is connected wireless.
the serial monitor is out putting dhcp ok
thank you for the quick responses!
peace
edit: the arduino does not get an ip automatically from dhcp :-(
That is a good sign! That means the ethernet shield is working, and the SPI is working. :slight_smile:
Now it is only a matter of software. How about this code?
#include <SPI.h>
  Serial.println("starting setup");
  delay(2000);
  Serial.println("setup ok");
Do you get “setup ok”?
yeah bro I get setup ok from the serial monitor
nothing in arp table though... pinging -> host unreachable
arp table! OK! Now we are talking! Some routers do not get an arp entry until the client ip attempts a connection. That code does nothing.
Can you ping 192.168.0.2? If so, then check arp table.
Edit: My bad. Missed that. Still no ping?
Is there an arp or dhcp entry in the router from the dhcp code?
BTW, "host unreachable" is normally a routing problem. What is the ip of the computer you are attempting the ping from?
no there is no entry in the arp table nor in cmd arp -a. my laptop ip is in the dhcp range 192.168.0.195. when I connect my laptop with a cable to the router my ip is not in the wireless dhcp range but something different can’t remember exactly. I guess it is something with my router…
ok, I can ping the arduino now :slight_smile: Man man, I was very stupid…
it appears that the default gateway is different for wireless and wired connections to the router. so I adapted the sketch with the default gateway for wired connections and i’m able to ping the arduino now. it does not show up in arp-a but I guess i can handle it from here. thank you for your help!!!
peace
