[Arduino Uno+CNC Shield V3+DRV8825] Steppers won't rotate
Hey guys,
I am currently making a CNC machine using Arduino Uno, CNC shield V3 with DRV8825 powered by a 12V 30A power supply. To drive the motors I load up GRBL into Arduino Uno and manually jog it using the Universal Gcode sender GUI. However, when I run it, the steppers will not rotate. The steppers vibrates and I hear humming noises coming from them. I have checked to make sure my stepper wires are connected correctly but the problem still persist.
Has anyone encountered this problem before? Please offer some advice.
Thank you :confused:
You will probably get better advice on CNC forum where people are familiar with GRBL. Maybe you have some of the configuration incorrect.
If you know what Arduino I/O pins are used for step and direction for each motor you should be able to adapt this Simple Stepper Code to test each motor on its own without GRBL.
…R
Stepper Motor Basics
Hey @Robin2,
I got it resolved. Turns out it was some wiring issues. Thanks
@helderpereiramartins
"me too" questions are most often NOT "me too" and so you may want to make your own post after using the two links below.
Also what you have done is considered NECRO posting and HIJACKING
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
