Arduino Uno code doesn´t work on Arduino Due
Hey Guys,
I never used an Arduino Due before so my knowledge about this specific board is basically zero.
I´ve copied some code for an Encoder from a blog post (Debounced Rotory Encoder – AZ-Delivery) and modified it slightly.
The code runs perfectly fine on my Arduino UNO and the LED Lights up every time I rotate the Encoder one notch but on my Arduino Due, which I need because I want to connect 6 Encoders in the end, the code just won´t work.
All wires are hooked up the same way on booth Arduinos.
I hope someone has an idea of what´s going wrong.
Here is my code:
#define encoderPinA 2
#define encoderPinB 3
#define SW 4
#define LED 8
volatile unsigned int encoderPos = 0; // a counter for the dial
unsigned int lastReportedPos = 1; // change management
static boolean rotating = false; // debounce management
int button = LOW;
int old_button = LOW;
// interrupt service routine variables
boolean A_set = false;
boolean B_set = false;
  pinMode(encoderPinA, INPUT);
  pinMode(encoderPinB, INPUT);
  pinMode( SW, INPUT_PULLUP );
  pinMode(LED, OUTPUT);
  digitalWrite(encoderPinA, HIGH); // turn on pullup resistors
  digitalWrite(encoderPinB, HIGH); // turn on pullup resistors
  attachInterrupt(0, doEncoderA, CHANGE); // encoder pin on interrupt 0 (pin 2)
  attachInterrupt(1, doEncoderB, CHANGE); // encoder pin on interrupt 1 (pin 3)
  Serial.begin(9600); // output to PC Serial Monitor
  delay(50);
  Serial.println("System Ready");
  delay(100);
digitalWrite(LED, HIGH);
delay(100);
digitalWrite(LED, LOW);
  //Serial.println("Entering Loop");
  //delay(50);
  rotating = true; // reset the debouncer
  if (lastReportedPos != encoderPos)
    actionPosition();
    lastReportedPos = encoderPos;
  button = !digitalRead( SW );
  if ( button != old_button )
    actionButton();
    delay( 10 );
    old_button = button;
  //Serial.println("Leaving Loop");
  //delay(50);
void actionButton()
  Serial.print("Button: ");
  delay(50);
  Serial.print ( button );
  delay(50);
  Serial.print (" | ");
  delay(50);
  Serial.println(encoderPos, DEC);
  delay(50);
void actionPosition()
  Serial.print("Position: ");
  delay(50);
  Serial.print(encoderPos, DEC);
  delay(50);
  delay(50);
  Serial.println ( button );
  delay(50);
// ISR Interrupt on A changing state (Increment position counter)
void doEncoderA()
  if ( rotating ) delay (1); // wait a little until the bouncing is done
  if ( digitalRead(encoderPinA) != A_set ) // debounce once more
    A_set = ! A_set;
    // adjust counter +1 if A leads B
    if ( A_set && ! B_set )
      encoderPos += 1;
    rotating = false; // no more debouncing until loop() hits again
// ISR Interrupt on B changing state, same as A above
void doEncoderB()
  if ( digitalRead(encoderPinB) != B_set )
    B_set = ! B_set;
    //adjust counter -1 if B leads A
    if ( B_set && ! A_set )
      encoderPos -= 1;
    rotating = false;
Edit:
It seems like the code gets stuck inside of the Interrupt.
Comments and code aren't coherent !
thank you, but how would this affect the functionality of the script?
ard_newbie:
I´m sorry I don´t understand.
It would be nice if you could explain it a litte bit more in depth.
I figured it out:
the Arduino Due isn´t able to execute delays inside of an Interrupt so it just won´t pass this line, removing it solved my problem
