Arduino UNO code error
I wanna to connect two w2812b led strips (one 10 leds to the inscription ,second under my desk 120leds) and put a fade colour.
And here i have question is it possible to run this two led strips by one arduino uno? I’m new in Arduino.
I tried to do a program ,by mix to programs but i have a error ‘‘expected primary-expression before ‘.’ token’’
#include <FastLED.h>
#define LED_PIN     5
#define NUM_LEDS    79
#define BRIGHTNESS  64
#define LED_TYPE    WS2812
#define COLOR_ORDER GRB
#define PIN 6
CRGB leds[NUM_LEDS];
#define UPDATES_PER_SECOND 100
#define strip  41, PIN;
CRGBPalette16 currentPalette;
TBlendType    currentBlending;
extern CRGBPalette16 myRedWhiteBluePalette;
extern const TProgmemPalette16 myRedWhiteBluePalette_p PROGMEM;
    delay( 3000 ); // power-up safety delay
    FastLED.addLeds<LED_TYPE, LED_PIN, COLOR_ORDER>(leds, NUM_LEDS).setCorrection( TypicalLEDStrip );
    FastLED.setBrightness(  BRIGHTNESS );
    strip.begin();
    strip.show();
    currentPalette = RainbowColors_p;
    currentBlending = LINEARBLEND;
    rainbow(20);
    rainbowCycle(20);
    theaterChaseRainbow(50);
    ChangePalettePeriodically();
    static uint8_t startIndex = 0;
    startIndex = startIndex + 1; /* motion speed */
    FillLEDsFromPaletteColors( startIndex);
    FastLED.show();
    FastLED.delay(1000 / UPDATES_PER_SECOND);
void FillLEDsFromPaletteColors( uint8_t colorIndex)
    uint8_t brightness = 255;
    for( int i = 0; i < NUM_LEDS; i++) {
        leds[i] = ColorFromPalette( currentPalette, colorIndex, brightness, currentBlending);
        colorIndex += 3;
// There are several different palettes of colors demonstrated here.
// FastLED provides several 'preset' palettes: RainbowColors_p, RainbowStripeColors_p,
// OceanColors_p, CloudColors_p, LavaColors_p, ForestColors_p, and PartyColors_p.
// Additionally, you can manually define your own color palettes, or you can write
// code that creates color palettes on the fly.  All are shown here.
void ChangePalettePeriodically()
    uint8_t secondHand = (millis() / 1000) % 60;
    static uint8_t lastSecond = 99;
    if( lastSecond != secondHand) {
        lastSecond = secondHand;
        if( secondHand ==  0)  { currentPalette = RainbowColors_p;         currentBlending = LINEARBLEND; }
        if( secondHand == 10)  { currentPalette = RainbowStripeColors_p;   currentBlending = NOBLEND;  }
        if( secondHand == 15)  { currentPalette = RainbowStripeColors_p;   currentBlending = LINEARBLEND; }
        if( secondHand == 20)  { SetupPurpleAndGreenPalette();             currentBlending = LINEARBLEND; }
        if( secondHand == 25)  { SetupTotallyRandomPalette();              currentBlending = LINEARBLEND; }
        if( secondHand == 30)  { SetupBlackAndWhiteStripedPalette();       currentBlending = NOBLEND; }
        if( secondHand == 35)  { SetupBlackAndWhiteStripedPalette();       currentBlending = LINEARBLEND; }
        if( secondHand == 40)  { currentPalette = CloudColors_p;           currentBlending = LINEARBLEND; }
        if( secondHand == 45)  { currentPalette = PartyColors_p;           currentBlending = LINEARBLEND; }
        if( secondHand == 50)  { currentPalette = myRedWhiteBluePalette_p; currentBlending = NOBLEND;  }
        if( secondHand == 55)  { currentPalette = myRedWhiteBluePalette_p; currentBlending = LINEARBLEND; }
// This function fills the palette with totally random colors.
void SetupTotallyRandomPalette()
    for( int i = 0; i < 16; i++) {
        currentPalette[i] = CHSV( random8(), 255, random8());
// This function sets up a palette of black and white stripes,
// using code.  Since the palette is effectively an array of
// sixteen CRGB colors, the various fill_* functions can be used
// to set them up.
void SetupBlackAndWhiteStripedPalette()
    // 'black out' all 16 palette entries...
    fill_solid( currentPalette, 16, CRGB::Black);
    // and set every fourth one to white.
    currentPalette[0] = CRGB::White;
    currentPalette[4] = CRGB::White;
    currentPalette[8] = CRGB::White;
    currentPalette[12] = CRGB::White;
// This function sets up a palette of purple and green stripes.
void SetupPurpleAndGreenPalette()
    CRGB purple = CHSV( HUE_PURPLE, 255, 255);
    CRGB green  = CHSV( HUE_GREEN, 255, 255);
    CRGB black  = CRGB::Black;
    currentPalette = CRGBPalette16(
                                   green,  green,  black,  black,
                                   purple, purple, black,  black,
                                   purple, purple, black,  black );
// This example shows how to set up a static color palette
// which is stored in PROGMEM (flash), which is almost always more
// plentiful than RAM.  A static PROGMEM palette like this
// takes up 64 bytes of flash.
const TProgmemPalette16 myRedWhiteBluePalette_p PROGMEM =
    CRGB::Red,
    CRGB::Gray, // 'white' is too bright compared to red and blue
    CRGB::Blue,
    CRGB::Black,
    CRGB::Red,
    CRGB::Gray,
    CRGB::Blue,
    CRGB::Black,
    CRGB::Red,
    CRGB::Red,
    CRGB::Gray,
    CRGB::Gray,
    CRGB::Blue,
    CRGB::Blue,
    CRGB::Black,
    CRGB::Black
void rainbow(uint8_t wait) {
  uint16_t i, j;
  for(j=0; j<256; j++) {
    for(i=0; i<strip.numPixels(); i++) {
      strip.setPixelColor(i, Wheel((i+j) & 255));
    strip.show();
    delay(wait);
void rainbowCycle(uint8_t wait) {
  uint16_t i, j;
  for(j=0; j<256*5; j++) { // 5 cycles of all colors on wheel
    for(i=0; i< strip.numPixels(); i++) {
      strip.setPixelColor(i, Wheel(((i * 256 / strip.numPixels()) + j) & 255));
    strip.show();
    delay(wait);
void theaterChaseRainbow(uint8_t wait) {
  for (int j=0; j < 256; j++) {     // cycle all 256 colors in the wheel
    for (int q=0; q < 3; q++) {
        for (int i=0; i < strip.numPixels(); i=i+3) {
          strip.setPixelColor(i+q, Wheel( (i+j) % 255));    //turn every third pixel on
        strip.show();
        delay(wait);
          strip.setPixelColor(i+q, 0);        //turn every third pixel off
uint32_t Wheel(byte WheelPos) {
  WheelPos = 255 - WheelPos;
  if(WheelPos < 85) {
   return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
  } else if(WheelPos < 170) {
    WheelPos -= 85;
   return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
   WheelPos -= 170;
   return strip Color(WheelPos * 3, 255 - WheelPos * 3, 0);
This line
make the precompiler replacing every occurrence of the string “strip” in the complete sketch by “41, PIN”. So in setup the compiler sees:
    41, PIN.begin();
    41, PIN.show();
The compiler tells you that this doesn’t make sense and it’s right.
I guess that you should have used “leds” instead of “strip” in these routines.
Hmm i think old code was terrible :smiley:
#define LED_PIN 5
#define LED_PINX 6
#define NUM_LEDS 79
#define NUM_LEDSX 41
#define BRIGHTNESS  128
CRGB leds[NUM_LEDS, NUM_LEDSX];
    FastLED.addLeds<LED_TYPE, LED_PIN, LED_PINX, COLOR_ORDER>(leds, NUM_LEDS, NUM_LEDSX ).setCorrection( TypicalLEDStrip );
    FastLED.show();
        colorIndex += 3;
    CRGB::Red,
    CRGB::Gray,
    CRGB::Blue,
    CRGB::Black,
    CRGB::Red,
    CRGB::Gray,
    CRGB::Blue,
    CRGB::Black,
    CRGB::Red,
    CRGB::Red,
    CRGB::Gray,
    CRGB::Gray,
    CRGB::Blue,
    CRGB::Blue,
    CRGB::Black,
    CRGB::Black
This is a new code but i wanna write that NUM_LEDS and NUM_LEDSX is the same.
I wrote this
but this it wrong i have error ‘‘expected ‘]’ before ‘,’ token’’
Suggestions:
  • Create two different ‘CRGB’ instances with two different variable names (one for each strip).
  • Use two separate ‘FastLED.addLeds’ lines.
  • Do whatever pixel manipulation you want on the two separate ‘CRGB’ instances.
  • When ready to update strips with new pixel information, ‘FastLED.show()’ will update both strips with one call.
  • Get rid of the ‘FastLED.delay()’ and learn to use ‘millis()’ timer as described in File --> Examples --> 02.Digital --> BlinkWithoutDelay
Can You help me with this? Im new in Arduino... :slight_smile:
Here’s an outline. To learn how to do the timing in ‘loop()’, study ‘File → Examples → 02.Digital → BlinkWithoutDelay’ as I suggested.
#define LED_PIN1 5
#define LED_PIN2 6
#define NUM_LEDS1 79
#define NUM_LEDS2 41
CRGB strip1[NUM_LEDS1];
CRGB strip2[NUM_LEDS2];
  delay(1000); // power-up safety delay
  FastLED.addLeds<LED_TYPE, LED_PIN1, COLOR_ORDER>(strip1, NUM_LEDS1);
  FastLED.addLeds<LED_TYPE, LED_PIN2, COLOR_ORDER>(strip2, NUM_LEDS2);
  // All LEDs off
  fill_solid(strip1, NUM_LEDS1, CRGB::Black);
  fill_solid(strip2, NUM_LEDS2, CRGB::Black);
  FastLED.show();
// if (it's time to update the strips) {
//   update pixels in both strips as desired
     FastLED.show();
Now i have this if i change NUM_LEDS1 to NUM_LEDS2 and strips1 to strip2 i have lighted one of them.
I used 1h to do new void loop but i think this is to hard for me hahah. @gfvalvo can you help?
My actual code:
#define LED_PIN1 5
#define LED_PIN2 6
    delay( 1000 ); // power-up safety delay
    FastLED.show();
    for( int i = 0; i < NUM_LEDS1; i++) {
        strip1[i] = ColorFromPalette( currentPalette, colorIndex, brightness, currentBlending);
        colorIndex += 3;
    CRGB::Red,
    CRGB::Gray,
    CRGB::Blue,
    CRGB::Black,
    CRGB::Red,
    CRGB::Gray,
    CRGB::Blue,
    CRGB::Black,
    CRGB::Red,
    CRGB::Red,
    CRGB::Gray,
    CRGB::Gray,
    CRGB::Blue,
    CRGB::Blue,
    CRGB::Black,
    CRGB::Black
