Arduino UNO - Controling LED strip with presure sensor & pulse sensor
Hi all, I am new to forums and hope someone can help me.
I have two separate sketches both working fine, the pressure sensor and the pulse sensor; alone these are fine but when I try to combine both they stop working on me can anyone please help ? =(
//Code for pressure sensor
int fsrAnalogPin = 0; // FSR is connected to analog 0
int LEDpin0 = 11; // connect Red LED to pin 11 (PWM pin)
int LEDpin1 = 10;
int LEDpin2 = 9;
int fsrReading; // the analog reading from the FSR resistor divider
int LEDbrightness;
void setup(void) {
Serial.begin(9600); // We’ll send debugging information via the Serial monitor
pinMode(LEDpin0, OUTPUT);
pinMode(LEDpin1, OUTPUT);
pinMode(LEDpin2, OUTPUT);
void loop(void) {
fsrReading = analogRead(fsrAnalogPin);
Serial.print("Analog reading = ");
Serial.println(fsrReading);
// we’ll need to change the range from the analog reading (0-1023) down to the range
// used by analogWrite (0-255) with map!
LEDbrightness = map(fsrReading, 0, 1023, 1, 255);
// LED gets brighter the harder you press
analogWrite(LEDpin0, LEDbrightness);
analogWrite(LEDpin1, LEDbrightness);
analogWrite(LEDpin2, LEDbrightness);
delay(100);
//Code for pulse sensor comes in two tabs this is the first tab
int analogPinR = 11;
int analogPinG = 10;
int analogPinB = 9;
//the buffer
int RGB[9];
//VALUES OF Red green and blue
int R=0;
int G=0;
int B=0;
int pulsePin = 1; // Pulse Sensor purple wire connected to analog pin 0
int fadeRate = 0; // used to fade LED on with PWM on fadePin
//int fadePin = 9; // pin to do fancy classy fading blink at each beat
//int fadePin1 = 10; // pin to do fancy classy fading blink at each beat
//int fadePin2 = 11; // pin to do fancy classy fading blink at each beat
// these variables are volatile because they are used during the interrupt service routine!
volatile int BPM; // used to hold the pulse rate
volatile int Signal; // holds the incoming raw data
volatile int IBI = 600; // holds the time between beats, the Inter-Beat Interval
volatile boolean Pulse = false; // true when pulse wave is high, false when it’s low
volatile boolean QS = false; // becomes true when Arduoino finds a beat.
Serial.begin(9600); // we agree to talk fast!
interruptSetup(); // sets up to read Pulse Sensor signal every 2mS
void loop(){
sendDataToProcessing(‘S’, Signal); // send Processing the raw Pulse Sensor data
if (QS == true){ // Quantified Self flag is true when arduino finds a heartbeat
fadeRate = 255; // Set ‘fadeRate’ Variable to 255 to fade LED with pulse
sendDataToProcessing(‘B’,BPM); // send heart rate with a ‘B’ prefix
sendDataToProcessing(‘Q’,IBI); // send time between beats with a ‘Q’ prefix
QS = false; // reset the Quantified Self flag for next time
delay(20); // take a break
if (BPM > 120){
pinMode(analogPinR,255); // pin that will blink to your heartbeat!
pinMode(analogPinG,0); // pin that will blink to your heartbeat!
pinMode(analogPinB,0); // pin that will blink to your heartbeat!
else if (BPM > 90){//yellow
pinMode(analogPinG,80); // pin that will blink to your heartbeat!
pinMode(analogPinB,5); // pin that will blink to your heartbeat!
else if (BPM > 85){//turk
pinMode(analogPinR,0); // pin that will blink to your heartbeat!
pinMode(analogPinG,204); // pin that will blink to your heartbeat!
pinMode(analogPinB,102); // pin that will blink to your heartbeat!
else if (BPM > 80){//green/blue
pinMode(analogPinG,255); // pin that will blink to your heartbeat!
pinMode(analogPinB,255); // pin that will blink to your heartbeat!
else if (BPM > 75){//blue/green
pinMode(analogPinG,128); // pin that will blink to your heartbeat!
else if (BPM > 70){//blue/purple
pinMode(analogPinR,102); // pin that will blink to your heartbeat!
pinMode(analogPinG,102); // pin that will blink to your heartbeat!
else if (BPM > 65){//purple
pinMode(analogPinR,178); // pin that will blink to your heartbeat!
else if (BPM > 60){//blue
//AURORA
else {//blue
delay(300);
//green
delay(300);
//orange
delay(300);
//yellow
delay(300);
//light blue
delay(300);
//purple
delay(300);
void ledFadeToBeat(){
fadeRate -= 15; // set LED fade value
fadeRate = constrain(fadeRate,0,255); // keep LED fade value from going into negative numbers!
// analogWrite(fadePin2,fadeRate); // fade LED
void sendDataToProcessing(char symbol, int data ){
Serial.print(symbol); // symbol prefix tells Processing what type of data is coming
Serial.println(data); // the data to send culminating in a carriage return
Serial.println(BPM); //print to the laptop screen
ledFadeToBeat();
if(Serial.available()==9){
for(int i =0;i<9;i++){
RGB*=Serial.read() - ‘0’;*
  • //get the data from the integer array*
    _ R= RGB[0]*100+RGB[1]*10+RGB[2];_
    _ G= RGB[3]*100+RGB[4]*10+RGB[5];_
    _ B= RGB[6]*100+RGB[7]*10+RGB[8];_
//this is the second tab
volatile int rate[10]; // used to hold last ten IBI values
volatile unsigned long sampleCounter = 0; // used to determine pulse timing
volatile unsigned long lastBeatTime = 0; // used to find the inter beat interval
volatile int P =512; // used to find peak in pulse wave
volatile int T = 512; // used to find trough in pulse wave
volatile int thresh = 512; // used to find instant moment of heart beat
volatile int amp = 100; // used to hold amplitude of pulse waveform
volatile boolean firstBeat = true; // used to seed rate array so we startup with reasonable BPM
volatile boolean secondBeat = true; // used to seed rate array so we startup with reasonable BPM
void interruptSetup(){
// Initializes Timer2 to throw an interrupt every 2mS.
TCCR2A = 0x02; // DISABLE PWM ON DIGITAL PINS 3 AND 11, AND GO INTO CTC MODE
TCCR2B = 0x06; // DON’T FORCE COMPARE, 256 PRESCALER
OCR2A = 0X7C; // SET THE TOP OF THE COUNT TO 124 FOR 500Hz SAMPLE RATE
TIMSK2 = 0x02; // ENABLE INTERRUPT ON MATCH BETWEEN TIMER2 AND OCR2A
sei(); // MAKE SURE GLOBAL INTERRUPTS ARE ENABLED
// THIS IS THE TIMER 2 INTERRUPT SERVICE ROUTINE.
// Timer 2 makes sure that we take a reading every 2 miliseconds
ISR(TIMER2_COMPA_vect){ // triggered when Timer2 counts to 124
cli(); // disable interrupts while we do this
Signal = analogRead(pulsePin); // read the Pulse Sensor
sampleCounter += 2; // keep track of the time in mS with this variable
int N = sampleCounter - lastBeatTime; // monitor the time since the last beat to avoid noise
// find the peak and trough of the pulse wave
if(Signal < thresh && N > (IBI/5)*3){ // avoid dichrotic noise by waiting 3/5 of last IBI
if (Signal < T){ // T is the trough
T = Signal; // keep track of lowest point in pulse wave
if(Signal > thresh && Signal > P){ // thresh condition helps avoid noise
P = Signal; // P is the peak
} // keep track of highest point in pulse wave
// NOW IT’S TIME TO LOOK FOR THE HEART BEAT
// signal surges up in value every time there is a pulse
if (N > 250){ // avoid high frequency noise
if ( (Signal > thresh) && (Pulse == false) && (N > (IBI/5)*3) ){
Pulse = true; // set the Pulse flag when we think there is a pulse
digitalWrite(analogPinR,HIGH); // turn on bluepin LED
digitalWrite(analogPinG,HIGH); // turn on redpin LED
digitalWrite(analogPinB,HIGH); // turn on greenpin LED
IBI = sampleCounter - lastBeatTime; // measure time between beats in mS
lastBeatTime = sampleCounter; // keep track of time for next pulse
if(firstBeat){ // if it’s the first time we found a beat, if firstBeat == TRUE
firstBeat = false; // clear firstBeat flag
return; // IBI value is unreliable so discard it
if(secondBeat){ // if this is the second beat, if secondBeat == TRUE
secondBeat = false; // clear secondBeat flag
for(int i=0; i<=9; i++){ // seed the running total to get a realisitic BPM at startup
rate *= IBI; *
  • // keep a running total of the last 10 IBI values*
  • word runningTotal = 0; // clear the runningTotal variable *
  • for(int i=0; i<=8; i++){ // shift data in the rate array*
    _ rate = rate[i+1]; // and drop the oldest IBI value_
    _ runningTotal += rate*; // add up the 9 oldest IBI values*
    * }*_
* rate[9] = IBI; // add the latest IBI to the rate array*
* runningTotal += rate[9]; // add the latest IBI to runningTotal*
* runningTotal /= 10; // average the last 10 IBI values*
* BPM = 60000/runningTotal; // how many beats can fit into a minute? that’s BPM! *
* QS = true; // set Quantified Self flag*
* // QS FLAG IS NOT CLEARED INSIDE THIS ISR*
* if (Signal < thresh && Pulse == true){ // when the values are going down, the beat is over*
// digitalWrite(analogPinR,LOW); // turn off red LED
// digitalWrite(analogPinG,LOW); // turn off green LED
// digitalWrite(analogPinB,LOW); // turn off blue LED
* Pulse = false; // reset the Pulse flag so we can do it again*
* amp = P - T; // get amplitude of the pulse wave*
* thresh = amp/2 + T; // set thresh at 50% of the amplitude*
* P = thresh; // reset these for next time*
* T = thresh;*
* if (N > 2500){ // if 2.5 seconds go by without a beat*
* thresh = 512; // set thresh default*
* P = 512; // set P default*
* T = 512; // set T default*
* lastBeatTime = sampleCounter; // bring the lastBeatTime up to date *
* firstBeat = true; // set these to avoid noise*
* secondBeat = true; // when we get the heartbeat back*
* sei(); // enable interrupts when youre done!*
}// end isr
