Arduino UNO, DC motor control with Bluetooth module
Hello, I build robot with arduino uno r3, arduino motor shield, 2xDC motor, and BT module.
I want conntrol robot with Android phone. I use ROcketBot android program, but i can control robot motors. BT connect to the device, but when I push buttons he don’t do my commands.
Meybe my program code is incorrect?
I use Samsung Galaxy S3 device.
#include <SoftwareSerial.h>
#include <Servo.h>
#define rxPin 5
#define txPin 6
// set up a new serial port
SoftwareSerial mySerial =  SoftwareSerial(rxPin, txPin);
Servo leftServo;  // create servo object to control a servo
Servo rightServo;  // create servo object to control a servo
int qualifier;
int dataByte;
  // define pin modes for tx, rx:
  pinMode(rxPin, INPUT);
  pinMode(txPin, OUTPUT);
  // set the data rate for the SoftwareSerial port
  mySerial.begin(9600);
  mySerial.begin(9600);   // HC05 bluetooth module
  leftServo.attach(21);
  leftServo.write(90);   // stop servo
  rightServo.attach(22);
  rightServo.write(90);  // stop servo
void loop() // run over and over
  if (mySerial.available())
    Serial.write(mySerial.read());
  if (Serial.available())
    mySerial.write(Serial.read());
  if(mySerial.available()>1)
    qualifier=mySerial.read();
    dataByte=mySerial.read();
    mySerial.print("qualifier = ");
    mySerial.println(qualifier);
    mySerial.print("dataByte = ");
    mySerial.println(dataByte);
    if ( qualifier == 68)
      if (dataByte == 1)
        forward();
      if (dataByte == 2)
        left();
      if (dataByte == 3)
        right();
      if (dataByte == 4)
        backward();
      if (dataByte == 5)
        stop();
void stop(){
void forward(){
  leftServo.write(0);              // go straight forward
  rightServo.write(120);
void backward(){
  leftServo.write(180);                // backward
  rightServo.write(60);
void left(){
  leftServo.write(140);                // go left
  rightServo.write(100);
void right(){
  leftServo.write(40);              // go right
  rightServo.write(80);
