Arduino Uno / DMD 32x16 matrix serial problems
Hello,
I am trying to get my 32x16 red matrix display to read text sent from serial and display it in text form however it just displays numbers.
#include <SPI.h>
#include <DMD2.h>
#include <fonts/SystemFont5x7.h>
#include <fonts/Droid_Sans_12.h>
// Set Width to the number of displays wide you have
const int WIDTH = 1;
// You can change to a smaller font (two lines) by commenting this line,
// and uncommenting the line after it:
const uint8_t *FONT = Droid_Sans_12;
//const uint8_t *FONT = SystemFont5x7;
SoftDMD dmd(WIDTH,1);  // DMD controls the entire display
DMD_TextBox box(dmd);  // "box" provides a text box to automatically write to/scroll the display
// the setup routine runs once when you press reset:
  dmd.setBrightness(255);
  dmd.selectFont(FONT);
  dmd.begin();
  Serial.write("Ready");
// the loop routine runs over and over again forever:
  // when characters arrive over the serial port...
  if (Serial.available()) {
    // wait a bit for the entire message to arrive
    delay(100);
    // clear the screen
    dmd.clearScreen();
    // read all the available characters
    while (Serial.available() > 0) {
      // display each character to the LCD
      box.print(Serial.read());
Above is my code. If anyone would be able to provide a solution that would be great.
Cheers, Dmk
Serial.read() is returning the ASCII code for the characters entered. As a start try
      box.print(Serial.read() - '0');
or
      box.print(Serial.read() - 48);
You will also need to take into account what you have got the line ending set to in the Serial monitor, if that is how you are entering numbers, otherwise you will see the ASCII code for it/them as well
