Jacarl
July 25, 2017, 9:43pm
#1
Hello Ive been working on a project all week when my board stop being recognized. I get this message:
Arduino: 1.8.3 (Windows 10), Board: "Arduino/Genuino Uno"
Sketch uses 928 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
avrdude: ser_open(): can't open device "\.\COM3": The system cannot find the file specified.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
option enabled in File -> Preferences.
Ive tried updating driver but the device comes back as ATmega328P not Arduino uno.
Thanks in advance!
pert
July 25, 2017, 10:05pm
#2
Select the port of your board from the Tools > Port menu.
cmiyc
July 26, 2017, 3:51am
#3
You can't "format" the board.
But it is possible to damage it. (For example, by changing connections while powered.)
Try doing what the error says, "Show verbose output..." and post it's output, with code tags.
Jacarl
July 26, 2017, 3:21pm
#4
@cmiyc
Arduino: 1.8.3 (Windows 10), Board: “Arduino/Genuino Uno”
<//C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Sam\Documents\Arduino\libraries -fqbn=arduino:avr:uno -ide-version=10803 -build-path C:\Users\Sam\AppData\Local\Temp\arduino_build_965816 -warnings=none -build-cache C:\Users\Sam\AppData\Local\Temp\arduino_cache_360577 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\Sam\Desktop\arduino\test\test.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Sam\Documents\Arduino\libraries -fqbn=arduino:avr:uno -ide-version=10803 -build-path C:\Users\Sam\AppData\Local\Temp\arduino_build_965816 -warnings=none -build-cache C:\Users\Sam\AppData\Local\Temp\arduino_cache_360577 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\Sam\Desktop\arduino\test\test.ino
Using board ‘uno’ from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Using core ‘arduino’ from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Detecting libraries used…
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino” “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard” “C:\Users\Sam\AppData\Local\Temp\arduino_build_965816\sketch\test.ino.cpp” -o “nul”
Generating function prototypes…
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino” “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard” “C:\Users\Sam\AppData\Local\Temp\arduino_build_965816\sketch\test.ino.cpp” -o “C:\Users\Sam\AppData\Local\Temp\arduino_build_965816\preproc\ctags_target_for_gcc_minus_e.cpp”
“C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags” -u --language-force=c++ -f - --c+±kinds=svpf --fields=KSTtzns --line-directives “C:\Users\Sam\AppData\Local\Temp\arduino_build_965816\preproc\ctags_target_for_gcc_minus_e.cpp”
Compiling sketch…
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino” “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard” “C:\Users\Sam\AppData\Local\Temp\arduino_build_965816\sketch\test.ino.cpp” -o “C:\Users\Sam\AppData\Local\Temp\arduino_build_965816\sketch\test.ino.cpp.o”
Compiling libraries…
Compiling core…
Using precompiled core
Linking everything together…
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc” -w -Os -g -flto -fuse-linker-plugin -Wl,–gc-sections -mmcu=atmega328p -o “C:\Users\Sam\AppData\Local\Temp\arduino_build_965816/test.ino.elf” “C:\Users\Sam\AppData\Local\Temp\arduino_build_965816\sketch\test.ino.cpp.o” “C:\Users\Sam\AppData\Local\Temp\arduino_build_965816/…\arduino_cache_360577\core\core_arduino_avr_uno_0c812875ac70eb4a9b385d8fb077f54c.a” “-LC:\Users\Sam\AppData\Local\Temp\arduino_build_965816” -lm
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-objcopy” -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 “C:\Users\Sam\AppData\Local\Temp\arduino_build_965816/test.ino.elf” “C:\Users\Sam\AppData\Local\Temp\arduino_build_965816/test.ino.eep”
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-objcopy” -O ihex -R .eeprom “C:\Users\Sam\AppData\Local\Temp\arduino_build_965816/test.ino.elf” “C:\Users\Sam\AppData\Local\Temp\arduino_build_965816/test.ino.hex”
Sketch uses 940 bytes (2%) of program storage space. Maximum is 32256 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM3 -b115200 -D -Uflash:w:C:\Users\Sam\AppData\Local\Temp\arduino_build_965816/test.ino.hex:i
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is “C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf”
Using Port : COM3
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: ser_open(): can’t open device “\.\COM3”: The system cannot find the file specified.
avrdude done. Thank you.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.>
pert
July 26, 2017, 3:27pm
#5
As already requested, please use code tags (</> button on the toolbar) when you post code or warning/error messages. The reason is that the forum software can interpret parts of your code as markup, leading to confusion, wasted time, and a reduced chance for you to get help with your problem. This will also make it easier to read your code and to copy it to the IDE or editor. If your browser doesn’t show the posting toolbar then you can just manually add the code tags:
[code]`` [color=blue]// your code is here[/color] ``[/code]
Using code tags and other important information is explained in the How to use this forum post . Please read it.
Did you try this?:
pert:
