Hi all, Have only done simple programs nothing like this . Is this posable ? wanting to be able to read and write bin file 32k in size onto a dallas DS1245 SRAMs. Have searched the net have no found anything . Please help .
So these:
The datasheet describes what you need to do:
But does a UNO have enough pins?
Or are you talking UNO R4?
What is the object of the exercise?
I have read the datasheet tbh it is above my head to do by myself.
Object is having a vehicle ecm that i could have multiple OS stored and switched with say a bluetooth phone .
I have a uno but if there is another platform that would work better i would change to it .
Here is my EEPROM programmer....Should be compatible with that SRAM too.
Why not use an SD Card instead?
That will be a lot easier, and there are plenty of examples available...
Again, what Arduino are you thinking of using?
On most, you will need to provide a bootloader to reprogram the microcontroller from your storage device...
I have a programing unit that uses the ds1245 chip for emulation of the eprom 27c256 was thinking i could join the two . could a sd card work like a 27c256?
