Arduino Uno ds18b20 and sure 2416 dor matrix display
hi guys
don't rell me how but now it WORKS !!!
this is the correct code
sensors.requestTemperatures();
int temp = sensors.getTempCByIndex(0);
Serial.println(temp,DEC);
char buffer[4];
itoa(temp,buffer,10);
ht1632_putchar(6 , 8, buffer[0]);
ht1632_putchar(12 , 8, buffer[1]);
// ht1632_putchar(12 , 8, buffer[2]);
// ht1632_putchar(18 , 8, buffer[3]);
ht1632_puttinychar(19 , 8, 'o');
ht1632_putchar(24 , 8, 'C');
delay(150);
only one question ( easy i think )
now it show the temperature in this format XX °C
and if I would like to show decimal ?
ie XX,X °C ?
how I should change it ?
Many thanks
Daniel
Based on snippets? Who knows? Post ALL of your code. Right now, we can only guess what sensors is.
Does that method return an int? Or a float?
Pauls Thank you for your answer
the kind of sensor il write on the topic and on the top post... SENSOR IS DALLAS DS18B20
the entire code was just posted so I repost
Thank you so much
Daniele
dallas 18B20.txt (15 KB)
  // returns temperature in degrees C
  float getTempC(uint8_t*);
  // returns temperature in degrees F
  float getTempF(uint8_t*);
  // Get temperature for device index (slow)
  float getTempCByIndex(uint8_t);
  float getTempFByIndex(uint8_t);
So, yes all the methods to get the temperature return a float, not an int.
Your buffer will need to be larger, and you'll need to use ftoa(), instead of itoa(). After that, you'll need to put more characters to the display.
thanks
so what i change ?
to
float temp = sensors.getTempCByIndex(0); ???
then ?
( I think I must change sometingh here but how ? )
char buffer[4];
Many thanks
Daniel
if i change
to
ftoa(temp,buffer,10);
I receive this error
lcd24x16_base___temperatura.cpp: In function 'void loop()':
lcd24x16_base___temperatura:112: error: 'ftoa' was not declared in this scope
where is the problem ?
Try dtostrf().
lcd24x16_base___temperatura:112: error: invalid conversion from 'char*' to 'signed char'
c:/users/daniele/desktop/varie2/arduino-0023/hardware/tools/avr/lib/gcc/../../avr/include/stdlib.h:581: error: too few arguments to function 'char* dtostrf(double, signed char, unsigned char, char*)'
lcd24x16_base___temperatura:112: error: at this point in file
danielb:
You aren't passing the correct number and type of arguments to dtostrf(). The documentation tells you what it expects. Only you know what you're actually providing, since we can't see your code, but it's obviously not correct. Change your code so it passes the arguments that the function expects.
I understand the kind of error but I don't know what I should write.
char buffer[8];
dtostrf(temp,buffer,10); <====== Float temp inside to buffer in decimal type but how change it ?
delay(150);
temp is the variable where the sensor give the reading of temperature
buffer is where temp goes
how convert by dtostrf float temp to buffer ?
the error is
what is double ?
what is signed char ?
what is unsigned char ?
what is char* ?
many thanks
Daniel
This has information about what the parameters need to be. If you have trouble interpreting it, post back with what you tried and why :slight_smile:
Cheers,
John
what is double ?
The value to be converted.
The width of the string to be produced. Why an signed char? Beats me.
The precision - the number of places after the decimal point. Why an unsigned char? Beats me.
what is char* ?
The buffer where the string is to be created.
float someTemp = 14.5;
char buffer[10];
dtostrf(someTemp, 8, 3, buffer);
many thanks for you help
here what I write
//int temp = sensors.getTempCByIndex(0);
char buffer[10];
// itoa(temp,buffer,10);
dtostrf(temp, 8, 3, buffer);
ht1632_putchar(18 , 8, buffer[2]);
ht1632_putchar(24 , 8, buffer[3]);
ht1632_puttinychar(32 , 8, 'o');
ht1632_putchar(35 , 8, 'C');
delay(150);
in this way change only where the temp is writed on display
ie 22 degree is written in decimal position _ _ , 22 °C
but without comma
where is the error ? I feel to be near to solution
Many thanks
Daniel
I think you would do better to consider the code that Paul provided as an example and an opportunity to think about how it applies to your situation rather than something to just paste into your code and report back that it doesn't work.
You should ask yourself questions like
How wide do I want the number to be? e.g. "22.51345" would be 8 wide
What precision do I want it to have ? e.g. "-23.434" would be a precision of 3.
and
Is my buffer[] big enough to hold it?
Do I have room to put it on the LCD buffer[0], buffer[1], buffer[2],... buffer[width-1]
jhon thank you so much now with your details I've understand the meaning of it
I've changed the code here
char buffer[10];
dtostrf(temp, 5, 2, buffer);
ht1632_putchar(37 , 8, 'C');
delay(150);
now works perfectly
many thanks
Great!! Then we'll leave it at that for now :wink:
You are asking for 5 characters in the output, with two digits after the decimal point, so something like 23.45. Then, you are showing 4 characters on the LCD (23.4). Why?
