Arduino Uno dual double LM35 and dht11 code beginers
Hello everybody on this forum.
I'm complete newbie on programming arduino and need some help. I would like to connect 3 sensors (2xlm35 1xdht11) to arduino uno and display readings on lcd 16x4 via i2c adapter.
The script to read lm35 I use is:
#include <DHT11.h>
#include <Wire.h>
#include <LCD.h>
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);
// Addr, En, Rw, Rs, d4, d5, d6, d7, backlighpin, polarity
float cel()
  int pin;
  float c;
  pin=analogRead(A1);
  c = (500.0 * pin)/1023;
  return(c);
  lcd.begin(16,2);
  lcd.print("C=      ");
  float Celciusze = cel();
  lcd.setCursor(2,0);
  lcd.print(Celciusze);
The script to read dht11 I use is:
#include <DHT11.h>
#include <Wire.h>
#include <LCD.h>
int pin = A0;
DHT11 dht11(pin);
double Fahrenheit(double celsius) {
return ((double)(9 / 5) * celsius) + 32;
double Kelvin(double celsius) {
return celsius + 273.15;
lcd.begin(16, 2);
lcd.backlight();
lcd.clear();
lcd.print("Humidity & temp");
delay(3000);
lcd.clear();
lcd.print("Starting.....");
delay(3000);
int err;
float temp, humi;
if ((err = dht11.read(humi, temp)) == 0)
lcd.clear();
lcd.setCursor(0, 0);
lcd.print("Temp");
lcd.setCursor(0, 1);
lcd.print("Humidity");
lcd.setCursor(9, 0);
lcd.print(temp);
lcd.print(" C");
lcd.setCursor(9, 1);
lcd.print(humi);
lcd.print(" %");
delay(10000);
lcd.println();
lcd.print("Error No :");
lcd.print(err);
lcd.println();
Can someone help me to merge this two codes to read this 3 sensors at the same time?
Thanks in advance
This should get you close:
#include <dht.h>
#include <Wire.h>
#include <LCD.h>
const int DHT11Pin = A0;
const int LM35APin = A1;
const int LM35BPin = A2;
DHT11 dht11(DHT11Pin);
  lcd.begin(16, 2);
  lcd.backlight();
  lcd.clear();
  delay(3000);
  lcd.clear();
  delay(3000);
  int err;
  float temp1, humi;
  float CelciuszeA = cel(LM35APin);
  float CelciuszeB = cel(LM35BPin);
    lcd.clear();
    lcd.print("Temp");
    lcd.print(temp1);
    lcd.print(" C");
    lcd.print(humi);
    lcd.print(" %");
    lcd.print(CelciuszeA);
    lcd.print(CelciuszeB);
    delay(10000);
    lcd.println();
    lcd.print(err);
    lcd.println();
float cel(const int pin) {
  int value = analogRead(pin);
  float c = (500.0 * value) / 1023;
  return c;
