Arduino UNO + EasyVR Shield
Hi there, I am trying to command my arduino via EasyVR shield. I followed the instruction on some kind of tutorial on youtube, but I have many problems still.
Basically here’s what I’ve done:
  • Inserted six commands into Group 1 of EasyVR via Commander
  • Put the switch to SW
  • Used SoftSerial in order to be able to monitor the serial communication
Here’s my sketch. The problem is that when I enter the loop the shield always returns ‘-1’, never recognizing anything; I tried both the group 1 SD commands (which I trained) and the SI groups, but the recognition always failed.
Can anyone help me please?
Thasnk
#include <SoftwareSerial.h>
const int OUT_PIN_ST=5;
const int OUT_PIN_ED=11;
const int LED_PIN_GRN=6;
const int LED_PIN_RED=3;
const int PAUSA=5000;
const int BLINK_DELAY=500;
SoftwareSerial myserial (12,13);
//myserialSerial myserial (2,30);
//byte Serial=0;
//byte Serial=1;
void setup(){
 pinMode(OUT_PIN_ST,OUTPUT);
 pinMode(LED_PIN_GRN,OUTPUT);
 pinMode(OUT_PIN_ED,OUTPUT);
 pinMode(LED_PIN_RED,OUTPUT);
 //pinMode(Serial,INPUT);
// pinMode(Serial,OUTPUT);
Serial.println("preinit");
 reset();
 myserial.begin(9600);
 myserial.print('b');
 Serial.println("init");
 int i = 0;
 for(i=0;i<100;i++){
  if(myserial.read()=='o'){
    Serial.println("awake");
  delay(1);
myserial.print('x');
for(i=0; i<100; i++){
if(myserial.read()=='x'){
  Serial.println("x received");
//myserial.println("x received");
delay(1);
 myserial.print(' ');
for(i=0;i<100;i++){
 if(myserial.read()=='B'){
   Serial.println("ok fw");
 delay(1);
myserial.print('l');
myserial.print('B');
for(i=0;i<100;i++){
   Serial.println("lingua");
 delay(1);
myserial.print('o');
myserial.print('A');
for(i=0;i<100;i++){
    Serial.println("timeout");
  delay(1);
myserial.print('d');
Serial.println("go");
//loopo();
void loop(){
Serial.println(myserial.read());
if(myserial.read()=='s'||myserial.read()=='r'){
  Serial.println("similar");
 delay(100);
if(myserial.read()=='A'||myserial.read()=='B'||myserial.read()=='C'||myserial.read()=='D'
||myserial.read()=='E'||myserial.read()=='F'){
  Serial.println("ok");
 program();
if(myserial.read()=='t'||myserial.read()=='e'){
  Serial.println("error");
 reset();
void dimLed(int ledPin){
  for(int fadeValue = 255 ; fadeValue >=0; fadeValue -=5) {
    // sets the value (range from 0 to 255):
    analogWrite(ledPin, fadeValue);
    // wait for 30 milliseconds to see the dimming effect
    delay(50);
void ampLed(int ledPin){
  for(int fadeValue = 0 ; fadeValue !=255; fadeValue +=5) {
    delay(50);
void blinkLed(int ledPin, int delayTime, int totalTime){
  int time=0;
  while(time<=totalTime){
    digitalWrite(ledPin,HIGH);
    delay(delayTime);
    digitalWrite(ledPin,LOW);
    delay(delayTime);
    time+=2*delayTime;
void program(){
 digitalWrite(OUT_PIN_ST, HIGH);
 delay(PAUSA/2);
 digitalWrite(OUT_PIN_ST,LOW);
 ampLed(LED_PIN_GRN);
 delay(PAUSA);
  dimLed(LED_PIN_GRN);
 ampLed(LED_PIN_RED);
 delay(PAUSA);
 blinkLed(LED_PIN_RED,BLINK_DELAY,PAUSA);
 digitalWrite(OUT_PIN_ED,HIGH);
 delay(PAUSA/2);
 digitalWrite(OUT_PIN_ED,LOW);
 unfuse();
void reset(){
void unfuse(){
 myserial.print('s');
Do you really have a myserial attached to those pins? Is there some reason not to use a meaningful name for the instance?
Maybe you need to do this 4 or 5 times, instead of just twice.
 delay(100);
Read, and do nothing more than print, if you are lucky enough to have read one, a character. Then, read another one, and do something with it. Why?
Hello,
I have an Arduino MEGA 2560 and the EasyVR shield. When I use EasyVR Commander, I can only train the trigger command. Everything else I try to train it tells me "Training Error: Recognition Failed".
This is the only issue I'm having since I can test the trigger command as well as the wordlist. I even tried using the same command on the group lists but even that tells me the message.
Any help is appreciated.
