First time using Arduino Uno and new to programming. Tried to upload a basic blink code to test if the board works. Using Arduino IDE 2.3.6. Keep getting the same errors:
avrdude: ser_open(): can't open device "\.\COM3": The semaphore timeout period has expired.
Failed uploading: uploading error: exit status 1
Looked up this forum, found a solution to turn off bluetooth so the COM ports work but my ports are standard serial over bluetooth link so when i turn off bluetooth, the ports disable as well unable to connect to my arduino uno. Any possible way to overcome this or is my laptop unable to perform the connection?
The number one issue I would be seeing is that you are either selecting the wrong COM port (Arduino IDE -> Tools -> Port), or that you don't have the right drivers installed (CH340 or CP2102 or FTDI etc.) so that the right COM port even shows up.
Here is a screen grab showing you which port to use. The alphabet part may be different, but as long as it has USB in the name that is the one. The other way of looking at it is you do NOT want the debug and you do NOT want the bluetooth.
I am using USB but it's my port that apparently requires bluetooth or else it'll disconnect from the USB. I'm suspecting it's an issue with my drivers.
Hi @john8117. This error might be caused by having the wrong port selected from the Tools > Port menu in Arduino IDE.
Please perform this experiment to verify that the port you have selected is your Arduino board:
With official boards, the port will be labeled with the board name in the menu (e.g., "COM42 (Arduino Uno)"). In this case, you can be fairly confident that you have identified the port. Select that port from the menu and try uploading again.
With some cheap derivative boards the port will not be labeled. You can positively identify the port using this procedure:
Disconnect the USB cable of the Arduino board from your computer.
Select Tools > Port from the Arduino IDE menus.
Take note of the ports (if any) listed in the menu.
Close the Tools menu. The ports list is only updated when the Tools menu is re-opened, so this step is essential.
Connect the Arduino board to your computer with a USB cable.
Select Tools > Port from the Arduino IDE menus. - If a new port is listed in the menu, that is the port of your Arduino board.
If you saw a new port appear at the last step, select that port from the Tools > Port menu and try uploading again.
If this doesn't solve the problem, please reply here on this forum topic with the answers to the following questions:
While following those instructions, did you see a port in the Tools > Port menu at step (6) that was not present at step (3)?
If you did see a new port, was the upload successful after you selected that port?
I think the OP isn't running MacOS, the "COM3" device name suggests me it's Windows instead... ;-)
Never heard of a COM port requiring Bluetooth (which Bluetooth? Connected with what?), and I can't get the "disconnect from the USB" either...
Please describe your steps in detail.
