Arduino uno + esp-01 + lcd (not working)
I used 4 sensor with arduino uno and also connected it to blynk, i also want to display the output in LCD but when i upload the lcd code the its not running, but without the lcd code its running in blynk. what should i do ?
this my code without LCD (this code is running with blynk)
#define BLYNK_PRINT Serial
#define BLYNK_TEMPLATE_ID ""
#define BLYNK_TEMPLATE_NAME ""
#define BLYNK_AUTH_TOKEN ""
#include <OneWire.h>
#include <DallasTemperature.h>
#include <Wire.h>
#include <ESP8266_Lib.h>
#include <BlynkSimpleShieldEsp8266.h>
// Your WiFi credentials.
// Set password to "" for open networks.
const char auth[] = BLYNK_AUTH_TOKEN;
char ssid[] = "";
char pass[] = "";
#include <SoftwareSerial.h>
SoftwareSerial EspSerial(2, 3);  // RX, TX
// Your ESP8266 baud rate:
#define ESP8266_BAUD 9600
OneWire oneWire(4);                   // Pin 2 is used for the OneWire interface
DallasTemperature sensors(&oneWire);  // Pass the OneWire reference to DallasTemperature library
ESP8266 wifi(&EspSerial);
float calibration_value = 22.85;
int phval = 0;
unsigned long int avgval;
int buffer_arr[10], temp;
int temperature;
int turb ;
float ph ;
int tds ;
const int tdsPin = A1;  // Analog input pin for TDS sensor
BlynkTimer timer;
  // Debug console
  delay(10);
  // Set ESP8266 baud rate
  EspSerial.begin(ESP8266_BAUD);
  delay(10);
  Blynk.begin(BLYNK_AUTH_TOKEN, wifi, ssid, pass);
    timer.setInterval(1000L, getSendData);
  Blynk.run();
    timer.run();
void getSendData(){
  // Temperature
  sensors.requestTemperatures();                   // Request temperature readings from the sensor
  float temperature = sensors.getTempCByIndex(0);  // Get the temperature in Celsius
  // Turbidity
  int turbidity = analogRead(A2);
  float turb = turbidity * (5.0 / 1024.0) * 3;
  // pH
  for (int i = 0; i < 10; i++) {
    buffer_arr[i] = analogRead(A0);
  for (int i = 0; i < 9; i++) {
    for (int j = i + 1; j < 10; j++) {
      if (buffer_arr[i] > buffer_arr[j]) {
        temp = buffer_arr[i];
        buffer_arr[i] = buffer_arr[j];
        buffer_arr[j] = temp;
  avgval = 0;
  for (int i = 2; i < 8; i++) {
    avgval += buffer_arr[i];
  float volt = (float)avgval * 5.0 / 1024 / 6;
  ph = -5.70 * volt + calibration_value;
  int tdsValue = analogRead(tdsPin);
  float voltage2 = tdsValue * (5.0 / 1024.0);
  float tds = voltage2 * 1000;  // Convert to TDS value (adjust the conversion factor as per your sensor)
Serial.print("temp: ");
Serial.println(temperature);
Serial.print("turb: ");
Serial.println(turb);
Serial.print("ph: ");
Serial.println(ph);
Serial.print("tds: ");
Serial.println(tds);
Blynk.virtualWrite(V0, temperature);
Blynk.virtualWrite(V1, turb);
Blynk.virtualWrite(V2, ph);
Blynk.virtualWrite(V3, tds);
but when i put this code with lcd it's not running also didn't display anything in serial monitor
#include <Wire.h>
char ssid[] = "";
char pass[] = "";
LiquidCrystal_I2C lcd(0x27, 20, 4);   // I2C address may vary, adjust as necessary
int phval = 0;
int temperature;
int turb ;
float ph ;
int tds ;
BlynkTimer timer;
  // Debug console
  delay(10);
  delay(10);
      Lcd();
void Lcd() {
  lcd.init();       // Initialize the LCD
  lcd.backlight();  // Turn on the backlight
  Blynk.run();
    timer.run();
void getSendData(){
  // Temperature
  // Turbidity
  // pH
  avgval = 0;
  lcd.setCursor(0, 0);
  lcd.print("checking ");
Serial.println(ph);
what should i do ?
