Arduino UNO, ESP8266 and BLYNK internet connection not responsive + button not working
I am trying to power on a Motor Driver which will enable a water pump to turn on using a simple application that I created using Blynk. However, the internet connection just stays up for something like 5 seconds, and then it disconnects. It does this continuously, hence the whole system is just not functional. I have tried testing the button during the short period of time that it connects to the internet and it is also not working. The button is the one that I want to use to switch on or off the motor driver.
Here is my code:
    #define BLYNK_PRINT Serial
    #include <SoftwareSerial.h>
    #include <ESP8266_Lib.h>
    #include <BlynkSimpleShieldEsp8266.h>
    int sensor_raw_data;
    int mapped_data;
    int pump;
    SoftwareSerial esdata(3,4);
    #define auth "XXXXXXX"
    #define ssid "XXXXXXX"
    #define pass "XXXXXXX"
    ESP8266 wifi(&esp8266);
     // Send AT commands
     String sendAT(String cmd, const int tmeout) {
       String rsp = "";
       esdata.print(cmd);
       long int time = millis();
      while((time + tmeout) > millis()) {
        while(esdata.available()) {
        char c = esdata.read();
        rsp += c;
      Serial.print(rsp);
      return rsp;
      esdata.begin(9600);
      Blynk.begin(auth, wifi, ssid, pass);
      sendAT("AT+RST\r\n", 2000);
      sendAT("AT\r\n", 1000);
      sendAT("AT+CWMODE=1\r\n", 1000);
      sendAT("AT+CWJAP=\""said"\",\""pass"\"\r\n", 2000);
      while(!esdata.find("OK")) {
      sendAT("AT+CIFSR\r\n", 1000);
      sendAT("AT+CIPMUX=0\r\n", 1000);
      pinMode(A0, INPUT);
      pinMode(8, OUTPUT);
      Blynk.run();
      sensor_raw_data = analogRead(A0);
      mapped_data=map(sensor_raw_data, 0, 1023, 100, 0);
      String sensor_value = String(mapped_data);
      Serial.print("Sensor Data: ");
      Serial.println(mapped_data);
      // Display the soil moisture on a gauge. // This is working   properly
     Blynk.virtualWrite(V5, prdata);
      // Send notification if soil moisture is below 80%
      if(mapped_data < 80) {
      Blynk.notify("Soil Moisture Is Below 80%. Turn On Water Pump.");
        Blynk.notify("Soil Moisture Is Above 80%. Turn Off Water Pump.");
      String pmp = String(pump);
      updateTS(sensor_value, pmp);
      delay(2000);
This is the function for the button. In my app, the button is Virtual pin 8. The Motor Driver is connected to Digital pin 8 on the Arduino. Is there something wrong with the function? Or maybe there is actually another way to let the button switch on or off the pump.
BLYNK_WRITE(V8) {
         int pinValue = param.asInt();
          if(pinValue == 1) {
            digitalWrite(8, HIGH);
            // This is the value that will be displayed for the pump status in thingspeak API graph.
            pump = 100;
            digitalWrite(8, LOW);
            pump = 0;
Have you commented out everything BUT the WIFI connection, does it remain? Then uncomment a few lines of other code. test it, does WiFI remain? Continue to uncomment till issue shows back up. Now you've got an area to ork on.
