Arduino UNO+ESP8266+DHT11 failed
Hi there,
I am trying to build a weather station, Arduino UNO+ESP8266+DHT11, and display the data on thingspeak.com.
I copied the code from https://www.instructables.com/id/Wireless-Temperature-and-Humidity-Monitor-With-ESP/. I justified the wifi name and code according to my house.
It seems the code was successfully uploaded to the UNO, but nothing happened on thingspeak channel page.
#include<stdlib.h>
#include "DHT.h"
#define SSID "2101"//your network name
#define PASS "01597928"//your network password
#define IP "184.106.153.149" // thingspeak.com
#define DHTPIN 7 // what pin the DHT sensor is connected to
#define DHTTYPE DHT11 // Change to DHT22 if that's what you have
#define Baud_Rate 115200 //Another common value is 9600
#define GREEN_LED 3 //optional LED's for debugging
#define RED_LED 4 //optional LED's for debugging
#define DELAY_TIME 60000 //time in ms between posting data to ThingSpeak
//Can use a post also
String GET = "GET /update?key=GLPFYKKUA6YN5QW1&field1=";
String FIELD2 = "&field2=";
//if you want to add more fields this is how
//String FIELD3 = "&field3=";
bool updated;
DHT dht(DHTPIN, DHTTYPE);
//this runs once
Serial.begin(Baud_Rate);
Serial.println("AT");
delay(5000);
if(Serial.find("OK")){
//connect to your wifi netowork
bool connected = connectWiFi();
if(!connected){
//failure, need to check your values and try again
Error();
}else{
Error();
//initalize DHT sensor
dht.begin();
//this runs over and over
void loop(){
float h = dht.readHumidity();
// Read temperature as Fahrenheit (isFahrenheit = true)
float f = dht.readTemperature(true);
// Check if any reads failed and exit early (to try again).
if (isnan(h) || isnan(f)) {
LightRed();
return;
//update ThingSpeak channel with new values
updated = updateTemp(String(f), String(h));
//if update succeeded light up green LED, else light up red LED
if(updated){
LightGreen();
}else{
LightRed();
//wait for delay time before attempting to post again
delay(DELAY_TIME);
bool updateTemp(String tenmpF, String humid){
//initialize your AT command string
String cmd = "AT+CIPSTART="TCP","";
//add IP address and port
cmd += IP;
cmd += "",80";
//connect
Serial.println(cmd);
delay(2000);
if(Serial.find("Error")){
return false;
//build GET command, ThingSpeak takes Post or Get commands for updates, I use a Get
cmd = GET;
cmd += tenmpF;
cmd += FIELD2;
cmd += humid;
//continue to add data here if you have more fields such as a light sensor
//cmd += FIELD3;
//cmd += <field 3 value>
cmd += "\r\n";
//Use AT commands to send data
Serial.print("AT+CIPSEND=");
Serial.println(cmd.length());
if(Serial.find(">")){
//send through command to update values
Serial.print(cmd);
}else{
Serial.println("AT+CIPCLOSE");
//success! Your most recent values should be online.
return true;
}else{
return false;
boolean connectWiFi(){
//set ESP8266 mode with AT commands
Serial.println("AT+CWMODE=1");
delay(2000);
//build connection command
String cmd="AT+CWJAP="";
cmd+=SSID;
cmd+="","";
cmd+=PASS;
cmd+=""";
//connect to WiFi network and wait 5 seconds
delay(5000);
//if connected return true, else false
return true;
}else{
return false;
void LightGreen(){
digitalWrite(RED_LED, LOW);
digitalWrite(GREEN_LED, HIGH);
void LightRed(){
digitalWrite(GREEN_LED, LOW);
digitalWrite(RED_LED, HIGH);
//if an error has occurred alternate green and red leds
void Error(){
while(true){
LightRed();
delay(2000);
LightGreen();
delay(2000);
I did not use the resistors, because I think the voltages for DHT11 (5V) and ESP8266 (3.3V) are OK, is that the source of my problem?
Did you test a single piece of the hardware before you connected the whole project together?
Why are you connecting the ESP to the ONLY port by which you could debug the process? Get the ESP off of Serial, so you can debug the program.
When you do that, tell us what the program actually does.
Hi Paul,
Just wait for a few minutes and it works, it took time for the data uploaded to the website. Now the system seems working well.
Yes, I broke the tx and rx between ESP and UNO when I upload the code to the UNO, or it will fail.
