#include <ESP8266WiFi.h>
const char *ssid = "Liq"; // replace with your wifi ssid and wpa2 key
const char *pass = "1234567";
WiFiClient client;
delay(10);
Serial.println("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, pass);
while (WiFi.status() != WL_CONNECTED)
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
In the boards sections, I have selected the the generic esp8266 module but still I am not being able to upload the the above code
I am getting the following error message:
Arduino: 1.8.13 (Windows Store 1.8.42.0) (Windows 10), Board: "Arduino, Primo, 80 MHz, Flash, Legacy (new can return nullptr), All SSL ciphers (most compatible), 4MB (FS:2MB OTA:~1019KB), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
Executable segment sizes:
IROM : 242804 - code in flash (default or ICACHE_FLASH_ATTR)
IRAM : 26892 / 32768 - code in IRAM (ICACHE_RAM_ATTR, ISRs...)
DATA : 1260 ) - initialized variables (global, static) in RAM/HEAP
RODATA : 796 ) / 81920 - constants (global, static) in RAM/HEAP
BSS : 25000 ) - zeroed variables (global, static) in RAM/HEAP
Sketch uses 271752 bytes (26%) of program storage space. Maximum is 1044464 bytes.
Global variables use 27056 bytes (33%) of dynamic memory, leaving 54864 bytes for local variables. Maximum is 81920 bytes.
esptool.py v2.8
Serial port COM3
Connecting........_____....._____....._____....._____....._____....._____.....____Traceback (most recent call last):
File "C:\Users\Devashish\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.7.4/tools/upload.py", line 65, in <module>
esptool.main(cmdline)
File "C:/Users/Devashish/Documents/ArduinoData/packages/esp8266/hardware/esp8266/2.7.4/tools/esptool\esptool.py", line 2890, in main
esp.connect(args.before)
File "C:/Users/Devashish/Documents/ArduinoData/packages/esp8266/hardware/esp8266/2.7.4/tools/esptool\esptool.py", line 483, in connect
raise FatalError('Failed to connect to %s: %s' % (self.CHIP_NAME, last_error))
esptool.FatalError: Failed to connect to ESP8266: Timed out waiting for packet header
_
the selected serial port _
does not exist or your board is not connected
option enabled in File -> Preferences.
