is it possible to configure arduino with ethernet shield and other SPI Device(in my case it is PN532) ??
is yes then how to do it ?? i read somewhere on net abt SS pin but unable to get the exact result..and i m new to arduino!
Yes, it is possible to use more than one SPI device at a time. Note that the Ethernet shield is an SPI device, as is the SD card on the Ethernet shield. Both can be used at the same time.
Each SPI device needs a separate SS (slave select) pin, set LOW (with all others HIGH) to talk to the specific device.
Or post any code or links.
First of all thanks for the reply sir!
actually i havent started the project yet , i m on the preliminary phase ..i m just collecting every info regarding the components i'll be using so i wont be able to post!! i just wanted to know if it is able run my PN532 and ethernet shield with arduino or i have to search for other options.!!
Sir, can u plz post some link showing example how to control 2SPI devices with arduino!!
any help is much appreciated ![]()
Here is another forum user who uses three SPI devices now. SD, w5100 and RTC.
http://forum.arduino.cc/index.php?topic=187102.0
Your device has a difference in the bit order rather than mode and speed.
http://www.circuitsathome.com/tag/pn532
