Hi!
My name is Alberto, and I have a little problem about the combo in the title:
I've an official Arduino Uno, and mounted on top an official Ethernet shield. I've wired a buzzer into digital pin 12, via an 220ohm resistor. It sound way to low.
As a workaround, using an analog pin (A1), it sound correctly loud.
I've discovered that a beep before Ethernet.begin works flawless, and after is really low in volume. It's pin 12 used by Ethernet Shield? Thank you
