Arduino uno + ethernet shield
Salve a tutti
ho comprato un Arduino uno + ethernet shield with microsd
sto facendo delle prove…
e non riesco a far funzionare l’ethernet shield
ho provato questo codice di prova
 Chat  Server
 A simple server that distributes any incoming messages to all
 connected clients.  To use telnet to  your device's IP address and type.
 You can see the client's input in the serial monitor as well.
 Using an Arduino Wiznet Ethernet shield.
 Circuit:
 * Ethernet shield attached to pins 10, 11, 12, 13
 * Analog inputs attached to pins A0 through A5 (optional)
 created 18 Dec 2009
 by David A. Mellis
 modified 10 August 2010
 by Tom Igoe
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network.
// gateway and subnet are optional:
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte ip[] = { 192,168,78, 57 };
byte gateway[] = { 192,168,78, 252 };
byte subnet[] = { 255, 255, 0, 0 };
// telnet defaults to port 23
Server server(23);
boolean gotAMessage = false; // whether or not you got a message from the client yet
  // initialize the ethernet device
  Ethernet.begin(mac, ip, gateway, subnet);
  // start listening for clients
  server.begin();
  // open the serial port
  // wait for a new client:
  Client client = server.available();
  // when the client sends the first byte, say hello:
  if (client) {
    if (!gotAMessage) {
      Serial.println("We have a new client");
      client.println("Hello, client!");
      gotAMessage = true;
    // read the bytes incoming from the client:
    char thisChar = client.read();
    // echo the bytes back to the client:
    server.write(thisChar);
    // echo the bytes to the server as well:
    Serial.print(thisChar);
l’ip del arduino deve essere 192.168.78.57
l’ip del mio pc 192.168.78.70
il gateway ha ip 192.168.78.252
riesco a compilare ed uploadare il codice
ma dal client se faccio
>ping 192.168.78.57
Esecuzione di Ping 192.168.78.57 con 32 byte di dati:
Risposta da 192.168.78.57: byte=32 durata<1ms TTL=128
Statistiche Ping per 192.168.78.57:
    Pacchetti: Trasmessi = 4, Ricevuti = 4,
    Persi = 0 (0% persi),
Tempo approssimativo percorsi andata/ritorno in millisecondi:
    Minimo = 0ms, Massimo =  0ms, Medio =  0ms
al telnet invece
>telnet 192.168.78.57
Connessione a 192.168.78.57...Impossibile aprire una connessione con l'host. sul
la porta 23: Connessione non riuscita
nella finestra del serialMonitor non appare nulla
qualche idea?
risolto... c'era un led collegatio alla porta 11...
