Arduino UNO + Fingerprint sensor FPM10A
Como están todos?
Estoy manejando un sensor de huella digital FPM10A con arduino uno, me descargue la libreria <Adafruit_Fingerprint.h> del siguiente enlace GitHub - adafruit/Adafruit-Fingerprint-Sensor-Library: Arduino library for interfacing to the fingerprint sensor in the Adafruit shop. Ésta librería trae un sketch de ejemplo que se llama "enroll" para registrar las huellas en el sensor. Aquí el código:
  This is an example sketch for our optical Fingerprint sensor
  Designed specifically to work with the Adafruit BMP085 Breakout
  ----> http://www.adafruit.com/products/751
  These displays use TTL Serial to communicate, 2 pins are required to
  interface
  Adafruit invests time and resources providing this open source code,
  please support Adafruit and open-source hardware by purchasing
  products from Adafruit!
  Written by Limor Fried/Ladyada for Adafruit Industries.
  BSD license, all text above must be included in any redistribution
#include <Adafruit_Fingerprint.h>
#include <SoftwareSerial.h>
uint8_t id;
uint8_t getFingerprintEnroll();
// Software serial for when you dont have a hardware serial port
// pin #2 is IN from sensor (GREEN wire)
// pin #3 is OUT from arduino  (WHITE wire)
// On Leonardo/Micro/Yun, use pins 8 & 9. On Mega, just grab a hardware serialport
SoftwareSerial mySerial(2, 3);
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);
// On Leonardo/Micro or others with hardware serial, use those! #0 is green wire, #1 is white
//Adafruit_Fingerprint finger = Adafruit_Fingerprint(&Serial1);
  while (!Serial);  // For Yun/Leo/Micro/Zero/...
  Serial.println("Adafruit Fingerprint sensor enrollment");
  // set the data rate for the sensor serial port
  finger.begin(57600);
  if (finger.verifyPassword()) {
    Serial.println("Found fingerprint sensor!");
    Serial.println("Did not find fingerprint sensor :(");
    while (1);
uint8_t readnumber(void) {
  uint8_t num = 0;
  boolean validnum = false;
  while (1) {
    while (! Serial.available());
    char c = Serial.read();
    if (isdigit(c)) {
       num *= 10;
       num += c - '0';
       validnum = true;
    } else if (validnum) {
      return num;
void loop()                     // run over and over again
  Serial.println("Ready to enroll a fingerprint! Please Type in the ID # you want to save this finger as...");
  id = readnumber();
  Serial.print("Enrolling ID #");
  Serial.println(id);
  while (!  getFingerprintEnroll() );
uint8_t getFingerprintEnroll() {
  int p = -1;
  Serial.print("Waiting for valid finger to enroll as #"); Serial.println(id);
  while (p != FINGERPRINT_OK) {
    p = finger.getImage();
    switch (p) {
    case FINGERPRINT_OK:
      Serial.println("Image taken");
    case FINGERPRINT_NOFINGER:
      Serial.println(".");
    case FINGERPRINT_PACKETRECIEVEERR:
      Serial.println("Communication error");
    case FINGERPRINT_IMAGEFAIL:
      Serial.println("Imaging error");
    default:
      Serial.println("Unknown error 1");
  // OK success!
  p = finger.image2Tz(1);
  switch (p) {
      Serial.println("Image converted");
    case FINGERPRINT_IMAGEMESS:
      Serial.println("Image too messy");
      return p;
      return p;
    case FINGERPRINT_FEATUREFAIL:
      Serial.println("Could not find fingerprint features");
      return p;
    case FINGERPRINT_INVALIDIMAGE:
      return p;
    default:
      Serial.println("Unknown error 2");
      return p;
  Serial.println("Remove finger");
  delay(2000);
  p = 0;
  while (p != FINGERPRINT_NOFINGER) {
  Serial.print("ID "); Serial.println(id);
  p = -1;
  Serial.println("Place same finger again");
    switch (p) {
      Serial.print(".");
    default:
      Serial.println("Unknown error 3");
  // OK success!
  p = finger.image2Tz(2);
  switch (p) {
      return p;
      return p;
      return p;
      return p;
    default:
      Serial.println("Unknown error 4");
      return p;
  // OK converted!
  Serial.print("Creating model for #");  Serial.println(id);
  p = finger.createModel();
  if (p == FINGERPRINT_OK) {
    Serial.println("Prints matched!");
  } else if (p == FINGERPRINT_PACKETRECIEVEERR) {
    return p;
  } else if (p == FINGERPRINT_ENROLLMISMATCH) {
    Serial.println("Fingerprints did not match");
    return p;
    Serial.println("Unknown error 5");
    return p;
  p = finger.storeModel(id);
    Serial.println("Stored!");
    return p;
  } else if (p == FINGERPRINT_BADLOCATION) {
    Serial.println("Could not store in that location");
    return p;
  } else if (p == FINGERPRINT_FLASHERR) {
    Serial.println("Error writing to flash");
    return p;
    Serial.println("Unknown error 6");
    return p;
Al subirlo al arduino y ejecutar el monitor serial, pide un ID, que es un número para darle ese espacio y almacenar la huella ( puede almacenar 162 huellas), vi un vídeo donde le daban al ID el valor de 6 y guardaba perfectamente, al momento de hacer lo mismo desde mi monitor serial me sale el error de la imagen.
Alguien que me puede ayudar con esto!!!??? No soy experto en arduino
Usa las librerías originales, yo también tenía el mismo error hasta que lo encontré:
Buen día,
Tengo una inquietud al respecto: yo también compré un sensor de la misma referencia, pero al realizar la conexión respectiva a un Arduino UNO, no me enciende ni siquiera los LEDS propios del sensor y, por ende, no me reconoce el sensor en el monitor serial (ni con la librería de Adafruit_Fingerprint.h ni con la FPM.h). La conexión la realicé con referencia a la imagen adjunta () y al siguiente video tutorial: lector de huella digital fingerprint con arduino - YouTube.
Mi pregunta es: ¿Es normal que no enciendan el sistema LED del sensor hasta que Arduino reconozca el sensor, o el sólo hecho de energizarlo ya es suficiente para que encienda?
Agradezco cualquier clase de ayuda al respecto,
Un saludo.
