Arduino UNO Fire Class rating
Hello,
I am using an Arduino Uno Rev3 board as part of a larger prototype that needs to conform to IEC 61010-1 standard. Part of if is to identify the fire class of all PCB but I cannot find if the arduino board has any ? The fire class, or flammability, is typicaly indicated by someting like UL 94 V-0.
Does anywone was confronted with a similar situation ?
Thanks
Use the Arduino to prototype the device, then design and have manufactured a PCB to your required spec.
It should be stamped on the board. The one genuine Arduino I have (I normally use clones) is marked with the UL 94V-0 rating.
Note that it only applies to the PCB itself and not the components on board.
Thanks CedarLakeInstrument, problem solved! I was looking at the documentation but didn't look under the PCB (already attached in the system).
