Here is a Pan Tilt Code for FLORA 9-DOF Accelerometer/Gyroscope/Magnetometer - LSM9DS0 (FLORA 9-DOF Accelerometer/Gyroscope/Magnetometer - LSM9DS0 [v1.0] : ID 2020 : $19.95 : Adafruit Industries, Unique & fun DIY electronics and kits):
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_LSM9DS0.h>
#include <Adafruit_9DOF.h>
/* Assign a unique base ID for this sensor */
Adafruit_LSM9DS0 lsm = Adafruit_LSM9DS0(1000); // Use I2C, ID #1000
Adafruit_9DOF dof = Adafruit_9DOF();
#define LSM9DS0_XM_CS 10
#define LSM9DS0_GYRO_CS 9
#define LSM9DS0_SCLK 13
#define LSM9DS0_MISO 12
#define LSM9DS0_MOSI 11
Configures the gain and integration time for the TSL2561
void configureSensor(void)
// 1.) Set the accelerometer range
lsm.setupAccel(lsm.LSM9DS0_ACCELRANGE_2G);
//lsm.setupAccel(lsm.LSM9DS0_ACCELRANGE_4G);
//lsm.setupAccel(lsm.LSM9DS0_ACCELRANGE_6G);
//lsm.setupAccel(lsm.LSM9DS0_ACCELRANGE_8G);
//lsm.setupAccel(lsm.LSM9DS0_ACCELRANGE_16G);
// 2.) Set the magnetometer sensitivity
lsm.setupMag(lsm.LSM9DS0_MAGGAIN_2GAUSS);
//lsm.setupMag(lsm.LSM9DS0_MAGGAIN_4GAUSS);
//lsm.setupMag(lsm.LSM9DS0_MAGGAIN_8GAUSS);
//lsm.setupMag(lsm.LSM9DS0_MAGGAIN_12GAUSS);
// 3.) Setup the gyroscope
lsm.setupGyro(lsm.LSM9DS0_GYROSCALE_245DPS);
//lsm.setupGyro(lsm.LSM9DS0_GYROSCALE_500DPS);
//lsm.setupGyro(lsm.LSM9DS0_GYROSCALE_2000DPS);
Arduino setup function (automatically called at startup)
void setup(void)
while (!Serial); // wait for flora/leonardo
Serial.println(F("LSM9DS0 9DOF Sensor Test")); Serial.println("");
/* Initialise the sensor */
if(!lsm.begin())
/* There was a problem detecting the LSM9DS0 ... check your connections */
Serial.print(F("Ooops, no LSM9DS0 detected ... Check your wiring or I2C ADDR!"));
while(1);
Serial.println(F("Found LSM9DS0 9DOF"));
/* Setup the sensor gain and integration time */
configureSensor();
/* We're ready to go! */
Serial.println("");
void loop(void)
/* Get a new sensor event */
sensors_event_t accel, mag, gyro, temp;
sensors_vec_t orientation;
lsm.getEvent(&accel, &mag, &gyro, &temp);
if (dof.fusionGetOrientation(&accel, &mag, &orientation))
/* 'orientation' should have valid .roll and .pitch fields */
Serial.print(F("Orientation: "));
Serial.print(orientation.roll);
Serial.print(F(" "));
Serial.print(orientation.pitch);
Serial.println(F(" "));
delay(1250);
