Arduino UNO Fried?
I was connecting LEDs to the digital output pins on my Arduino UNO, and I wanted to test to make sure they were hooked up properly. I connected 7 volts to each led, which was also connected directly to the digital ports on my arduino. The Arduino now won't load with code, and the blinking orange LED labeled L doesn't light up ever. When I try to download code, the compiler returns this: avrdude: stk500_getsync(): not in sync: resp=0x00.
One of the surface mount resistors or capacitors (too small to tell) heats up a lot whenever I turn on the arduino.
Did I fry my Arduino, or is there a method for fixing this issue?
Thanks
Unfortunately, yes, you probably did fry your Arduino. The number ONE rule should never connect an LED directly to any output pin and ground or +5v, without a proper (at least 220 ohm or more) resistor in series. And especially never connect more than +5v to any pin on the Arduino. You may be able to replace the ATmega328P chip but there is no telling what other component you may have fried on the board.
