Hey,
I build an Breadboard as Prototype for an LED Controler (controlls 2 different RGB Strips). The Arduino controls 6 Transistors, each leads to 1 GND Pin of one LED-Strip.
All worked fine, I created the PCB on PC an though before I make one, I test the circuit again. And now I sometimes have to wait almost 2 secconds for the Arduino to respond ( Change Lights). The Code runs without Delays and I tried to minimize the Time by reducing Debug Logs via USB to almost 0. Nothing makes it answer fast.
From my Phone I send CommandID's (and some data) to make it run.
These Commands work instand:
- 0 (On/Off)
- 4 (Fade)
- 8 (Sides)
These Commands work not instantly:
- 1 (Set LED's to Red) => 2s
- 2 (Set Random Color) => 1,5s
The other Commands (5, 6, 7) are not working [need to Debug], Modes 9-12 aren't even programmed yet.
So what can it be that this Delay is there? Interesting herefore is, that even the use of a button follows the Delay (Button Press sets commandID).
Here is the Code:
#include <SoftwareSerial.h>
// Define Pins
#define HC_RX 7 // 12
#define HC_TX 4 // 11
#define redPin_A 11
#define greenPin_A 10
#define bluePin_A 9
#define redPin_B 6
#define greenPin_B 5
#define bluePin_B 3
#define button_0 8
#define button_1 12
#define button_2 15
#define button_3 14
#define statusLED 13
// Variables
bool writeDebugLines = true;
float HC_CommunicationBaudrate = 9600.0;
char CommandStartChar = '*'; // Char to start an Command or String
int commandID; // ID of the read Command
int lastCommandID; // CommandID of the Command before the new command
bool lightsActivated = false; // Check if Output is activated
bool useDefaultColors;
int r,g,b; // First Side Colors
int r_2,g_2,b_2; // Seccond Side Colors;
int last_r, last_g, last_b; // Color Backups to save Memory and reduce Time
bool setLED;
unsigned long int millisMemory; // Stores the Time in ms
int fadePhaseIndex = 0; // Stores the current Phase of the FadeMode
unsigned int generallFadeTime = 100; // Stores the time in ms between two Fades
unsigned int generallCycleTime; // Stores the Time an Mode-Cycle needs
const unsigned int maxCycleTime = 65000;
const unsigned int minCycleTime = 1000;
float brightness = 1.0f; // Max Brightness of the Lights
bool brightnessChanged = false;
enum SideSelectionenum {Both, Side_A, Side_B};
const String SideSelectionNames[] = {"Both", "Side A", "Side B"};
SideSelectionenum selectedSide = Both;
int button_0_State = 0;
int button_1_State = 0;
int button_2_State = 0;
int button_3_State = 0;
// Define BT-Serial
SoftwareSerial btSerial(HC_TX, HC_RX); // TX | RX => von HC05 (From Arduino its other way round)
// Start Debugging to Computer via USB-Serial
if( writeDebugLines){
Serial.println("Los geht's");
Serial.println("Befehle:");
Serial.println("*1 => An-/Ausschalten");
Serial.println("*2 r g b (r_2, g_2, b_2) => Farbe darstellen => Klammer = optional");
Serial.println("*3 a => zufällige Farbe darstellen => a=2 > 2 Random Farben");
Serial.println("*4 => Fade durch die Farben");
Serial.println("*5 => Aktuelle Daten per Serial senden");
Serial.println("*6 time => Change FadeTime in ms");
Serial.println("*7 5-100 => Change Brightness in %");
Serial.println("*8 Cycle Sides");
Serial.println("*9 Flash");
Serial.println("*10 Custom Flash");
Serial.println("*11 Random Mode");
Serial.println("*12 Random LED");
// Start Bluetooth Connection
btSerial.begin(9600);
// Pin Stuff
pinMode(redPin_A, OUTPUT);
pinMode(greenPin_A, OUTPUT);
pinMode(bluePin_A, OUTPUT);
pinMode(redPin_B, OUTPUT);
pinMode(greenPin_B, OUTPUT);
pinMode(bluePin_B, OUTPUT);
pinMode(statusLED, OUTPUT);
pinMode(button_0, INPUT);
pinMode(button_1, INPUT);
pinMode(button_2, INPUT);
pinMode(button_3, INPUT);
// Variable Stuff
generallCycleTime = minCycleTime;
void loop() { // run over and over
CollectInput();
Process();
Output();
void CollectInput(){
HandleHC05Data();
HandleSerialData();
// Get ButtonInput
int button_0_currState = digitalRead(button_0);
int button_1_currState = digitalRead(button_1);
int button_2_currState = digitalRead(button_2);
int button_3_currState = digitalRead(button_3);
if(button_0_currState == 1 && button_0_State != 1){
// On / Off
button_0_State = button_0_currState;
if (writeDebugLines) Serial.println("Button 0 pressed");
commandID = 1;
else if(button_0_currState == 0 && button_0_State != 0){
if(!lightsActivated) return; // Stop here when lights are out
if(button_1_currState == 1 && button_1_State != 1){
// Mode
button_1_State = button_1_currState;
if (writeDebugLines) Serial.println("Button 1 pressed");
// Cycle trough Modes
if(commandID == 4 || commandID == 400) // Fade Mode
commandID = 9;
lastCommandID = 9;
else if (commandID == 2) // RGB
commandID = 3;
lastCommandID = 3;
else if (commandID == 3 || commandID == 0) // Random RGB
commandID = 4;
lastCommandID = 4;
else if (commandID == 9 || commandID == 10) // Flash
commandID = 12;
lastCommandID = 12;
else if(commandID == 12) // Random LED
commandID = 3;
lastCommandID = 3;
if(writeDebugLines)
Serial.print("New CommandID: ");
Serial.println(commandID);
else if(button_1_currState == 0 && button_1_State != 0){
if(button_2_currState == 1 && button_2_State != 1){
// Time
button_2_State = button_2_currState;
if(writeDebugLines) Serial.println("Button 2 pressed");
// Cycle trough Time
generallCycleTime += 5000;
if(generallCycleTime >= maxCycleTime){
if(writeDebugLines)
Serial.print("New CycleTime: ");
Serial.println((String)generallCycleTime);
RecalculateTimes();
else if(button_2_currState == 0 && button_2_State != 0){
if(button_3_currState == 1 && button_3_State != 1){
// LED's
button_3_State = button_3_currState;
if(writeDebugLines) Serial.println("Button 3 pressed");
// Cycle trough Sides
commandID = 8;
else if(button_3_currState == 0 && button_3_State != 0){
void Process(){
if(commandID == 1){
// Handle Lights Activasion
lightsActivated = !lightsActivated;
if(lightsActivated){
commandID = 2; // SetRGB Mode
useDefaultColors = true;
SendDataOverBoth("Activated Lights");
fadePhaseIndex = 0;
digitalWrite(statusLED, 1);
else{
commandID = 0;
r = 0;
g = 0;
b = 0;
setLED = true;
SendDataOverBoth("Deactivated Lights");
digitalWrite(statusLED, 0);
// Handle Modes
switch(commandID)
case 2:
// RGB Mode
if(useDefaultColors){
r=255;
g=255;
b=255;
useDefaultColors = false;
else{
r = btSerial.parseInt();
g = btSerial.parseInt();
b = btSerial.parseInt();
r_2 = btSerial.parseInt();
g_2 = btSerial.parseInt();
b_2 = btSerial.parseInt();
if(writeDebugLines)
Serial.print("R2: "); Serial.println(r_2);
Serial.print("G2: "); Serial.println(g_2);
Serial.print("B2: "); Serial.println(b_2);
setLED = true;
commandID = 0;
case 3:
// Random RGB
int a = btSerial.parseInt();
r = random(0,257);
g = random(0,257);
b = random(0,257);
if(a == 2 )
r_2 = random(0,257);
g_2 = random(0,257);
b_2 = random(0,257);
else{
r_2 = r;
g_2 = g;
b_2 = b;
setLED = true;
commandID = 0;
Serial.print("R1: "); Serial.println(r);
Serial.print("G1: "); Serial.println(g);
Serial.print("B1: "); Serial.println(b);
case 4:
// Fade Start
fadePhaseIndex = 0;
// Set first color and start Time
SendDataOverBoth("Started Fade");
millisMemory = millis();
r = 0;
g = 0;
b = 255;
setLED = true;
fadePhaseIndex++;
commandID = 400;
lastCommandID = 400;
r_2 = r;
g_2 = g;
b_2 = b;
RecalculateTimes();
case 400:
// Fade Cycle
if(millis() - millisMemory > generallFadeTime){
// Next Step after 100ms
if(fadePhaseIndex < 256){
// increase red => blue to violett
r++;
else if(fadePhaseIndex < 511){
// decrease blue => violet to red
b--;
else if(fadePhaseIndex < 766){
// increase green => red to yellow
g++;
else if(fadePhaseIndex < 1021){
// decrease red => yellow to green
r--;
else if(fadePhaseIndex < 1276){
// increase blue => green to tal
b++;
else if(fadePhaseIndex < 1531){
// decrease green => tal to blue
g--;
fadePhaseIndex++; // Increase Index for next Step
setLED = true; // Allow to set the LED Outpus
millisMemory = millis(); // Change LastTime to now
if(fadePhaseIndex >= 1531){
// Reset PhaseIndex to restart Fading
fadePhaseIndex = 0;
r_2 = r;
g_2 = g;
b_2 = b;
case 5:{
// Read current Data and return to lastCommand
SendDataOverBoth("Red: ");
SendDataOverBoth((String)r);
SendDataOverBoth("Green: ");
SendDataOverBoth((String)g);
SendDataOverBoth("Blue: ");
SendDataOverBoth((String)b);
SendDataOverBoth("Seite: ");
SendDataOverBoth((String)SideSelectionNames[selectedSide]);
commandID = lastCommandID;
case 6:{
// Change FadeTime and return to lastCommand
int _cycleTime = btSerial.parseInt();
if(_cycleTime > minCycleTime && _cycleTime < maxCycleTime){
// FadeTime between 10ms and 1min
generallCycleTime = _cycleTime;
SendDataOverBoth("New CycleTime: ");
SendDataOverBoth((String)generallCycleTime);
RecalculateTimes();
case 7:{
// Change Brightness and return to lastCommand
int bright = btSerial.parseInt();
if(bright >= 5 && bright <= 100){
brightness = bright /100.0f;
SendDataOverBoth("New Brightness: ");
SendDataOverBoth((String)brightness);
setLED = true;
brightnessChanged = true;
case 8:{
// Cycle trough Sides and return to lastCommand
switch (selectedSide){
case Both:
selectedSide = Side_A;
case Side_A:
selectedSide = Side_B;
case Side_B:
case 9:{
// Flash
case 10:{
// Custom Flash
case 11:{
// Random Mode
case 12:{
// Random LED
void RecalculateTimes(){
// Recalculate Times for every Cycle
if(commandID == 400 || commandID == 4){
// Fade Time
generallFadeTime = (float)generallCycleTime / 1531;
SendDataOverBoth("New FadeTime: ");
SendDataOverBoth((String)generallFadeTime);
else{
void Output(){
// In this Block the Output is set
if(setLED) WriteLEDLights();
// Read Data from HC05 to Serial
void HandleHC05Data(){
if (btSerial.available()) {
char data = btSerial.read();
//SendDataOverSerial(data);
if(data == CommandStartChar){
// Read Command
lastCommandID = commandID;
commandID = btSerial.parseInt();
SendDataOverSerial(commandID);
// Write the LED Lights to the Outputs
void WriteLEDLights(){
// Only write & Log the LED Pins that have changed. => Saves ressources and makes the Log more readable
// Write Red Pin
if(r != last_r || brightnessChanged){
if(selectedSide == Both || selectedSide == Side_A){
// Red Pin of Side A is active
analogWrite(redPin_A, r * brightness);
else{
// Red Pin of Side A is inactive
analogWrite(redPin_A, 0);
if(selectedSide == Both || selectedSide == Side_B){
// Red Pin of Side B is active
analogWrite(redPin_B, r * brightness);
else{
// Red Pin of Side B is inactive
analogWrite(redPin_B, 0);
last_r = r;
if(writeDebugLines) Serial.print("Red: "); Serial.println(r);
// Write Green Pin
if(g != last_g || brightnessChanged){
// Green Pin of Side A is active
analogWrite(greenPin_A, g * brightness);
else{
// Green Pin of Side A is inactive
analogWrite(greenPin_A, 0);
// Green Pin of Side B is active
analogWrite(greenPin_B, g * brightness);
else{
// Green Pin of Side B is inactive
analogWrite(greenPin_B, 0);
last_g = g;
if(writeDebugLines) Serial.print("Green: "); Serial.println(g);
// Write Blue Pin
if(b != last_b || brightnessChanged){
// Blue Pin of Side A is active
analogWrite(bluePin_A, b* brightness);
else{
// Blue Pin of Side A is inactive
analogWrite(bluePin_A, 0);
// Blue Pin of Side B is active
analogWrite(bluePin_B, b* brightness);
else{
// Blue Pin of Side B is inactive
analogWrite(bluePin_B, 0);
last_b = b;
if(writeDebugLines) Serial.print("Blue: "); Serial.println(b);
setLED = false;
// Send Data from Serial to HC05
void HandleSerialData(){
if (Serial.available()) {
char data = Serial.read();
SendDataOverHC05(Serial.readString());
else{
SendDataOverHC05(data);
void SendDataOverBoth(char data){
void SendDataOverBoth(String data){
void SendDataOverSerial(char data){
if(writeDebugLines) Serial.println(data);
void SendDataOverSerial(String data){
void SendDataOverHC05(char data){
btSerial.println(data);
void SendDataOverHC05(String data){
