Arduino Uno, high torque DC servo motor and ATX power supply
Beginner here, want to control 60kg servo with Arduino Uno. As servo uses 6v-8.4v I need to use external power supply. Will connect ground pin of Arduino and power supply ground as it is required.
Idea is to connect: 12V from ATX power supply->Dc In->Step-Down DC converter->Dc Out->60KG servo
As a beginner I do not know if this is appropriate solution to this issue or I need to change my approach and thinking?
Here is the dc servo: DS5160 Digital Metal Gear Servo Torque 60KG DS5160 Digital Metal Gear Servo Torque 60KG 180° 270° For RC Car Helicopter Boat | eBay
DC 300W 20A CC CV Constant Current Adjustable Step-Down Converter Voltage Buck: DC 300W 20A CC CV Constant Current Adjustable Step-Down Converter Voltage Buck | eBay
You MAY be able to get away with using the 5V from the PSU.
Connection data isnt shown.
Spec for a similar servo motor:
No. Operat voltage: 6V;8.4V
4.1 Idle current: 5mA; 5mA
4.2 No load speed: 0.17sec/60°;0.13sec/60°
4.3 Runnig current: 400mA;510mA
4.4 Peak stall torque: 58.5kg.cm;70kg.cm
4.5 Stall current: 8.5A±10%;10.4A±10%
4.6 Working voltage range: 4.8-8.4V
You could use the arduino to control a relay to turn the power to the servo on and off
Why would the OP want to do that? With no power to the servo you have no control and it may move under any load.
Steve
Thanks for the answers. I'm programmer and new to electro-mechanics so I want to learn step by step and avoid mistakes that will waste my time. Know some theory but have no one that I can talk to and to help me with this beginner steps. Had ordered first this step-down converter and will try to test it with some load; and amperemeter to check what it can provide in current. Afterwards I will going to buy and this 60kg servo.
But I want to precisely control angle, like 20 or 45 degrees, then back 15 degrees. For robot arm. I can not do this only with relay turning it on or off.
