Hi all my friends!
I have some problems with arduino + HMI connection. I think you can help me fix this problem.
-I still cannot complete the code in: void DSbutton bt6
-My aim: when you press bt6 on the 1st HMI, then execute commands in the while loop, when you press bt6 a second time, exit the while loop and turn off all the lights
-problems I do not find the condition to exit the while loop. Can you help me improve this code?
Thanks for reading and able to solve this problem for me
thanks
Here is the code:
#include "Nextion.h"
const int led_01 = 13;
const int led_02 = 12;
const int led_03 = 11;
const int led_04 = 10;
const int led_05 = 9;
const int led_06 = 8;
NexButton b0 = NexButton(1, 1, "b0");
NexButton b1 = NexButton(1, 5, "b1");
NexDSButton bt0 = NexDSButton(1, 2, "bt0");
NexDSButton bt1 = NexDSButton(1, 3, "bt1");
NexDSButton bt2 = NexDSButton(1, 4, "bt2");
NexDSButton bt3 = NexDSButton(1, 6, "bt3");
NexDSButton bt4 = NexDSButton(1, 7, "bt4");
NexDSButton bt5 = NexDSButton(1, 8, "bt5");
NexDSButton bt6 = NexDSButton(2, 2, "bt6");
// Registro al objeto Dual State Button a la lista de eventosTouch
NexTouch *nex_listen_list[] =
&b0, &b1,
&bt0, &bt1, &bt2, &bt3, &bt4, &bt5, &bt6,
NULL
// Creo que una funcion que ingresara cuando el evento Touch sea detectado
void b0_Apagar(void *ptr);
void b1_Apagar(void *ptr);
void Funcion_bt0(void *ptr);
void Funcion_bt1(void *ptr);
void Funcion_bt2(void *ptr);
void Funcion_bt3(void *ptr);
void Funcion_bt4(void *ptr);
void Funcion_bt5(void *ptr);
void Funcion_bt6(void *ptr);
void setup(void)
nexInit();//Inicio la comunicacion entre el Arduino y la Pantalla
pinMode(led_01, OUTPUT);
pinMode(led_02, OUTPUT);
pinMode(led_03, OUTPUT);
pinMode(led_04, OUTPUT);
pinMode(led_05, OUTPUT);
pinMode(led_06, OUTPUT);
digitalWrite(led_01, LOW);
digitalWrite(led_02, LOW);
digitalWrite(led_03, LOW);
digitalWrite(led_04, LOW);
digitalWrite(led_05, LOW);
digitalWrite(led_06, LOW);
//Registro el llamado a la funcion del evento de Dual State Button
b0.attachPop(b0_Apagar);
b1.attachPop(b1_Apagar);
bt0.attachPop(Funcion_bt0, &bt0);
bt1.attachPop(Funcion_bt1, &bt1);
bt2.attachPop(Funcion_bt2, &bt2);
bt3.attachPop(Funcion_bt3, &bt3);
bt4.attachPop(Funcion_bt4, &bt4);
bt5.attachPop(Funcion_bt5, &bt5);
bt6.attachPop(Funcion_bt6, &bt6);
void loop(void)
Cada vez que el evento sea llamado, se direccionara al correspondiente
evento del componente.
nexLoop(nex_listen_list);
digitalWrite(led_01, HIGH);
digitalWrite(led_02, HIGH);
digitalWrite(led_03, HIGH);
digitalWrite(led_04, HIGH);
digitalWrite(led_05, HIGH);
digitalWrite(led_06, HIGH);
void Funcion_bt0(void *ptr) {
uint32_t Estado_dual;/* Consigo el valor del estado del componente. */
bt0.getValue(&Estado_dual);
if (Estado_dual) {
else {
void Funcion_bt1(void *ptr) {
bt1.getValue(&Estado_dual);
if (Estado_dual) {
else {
void Funcion_bt2(void *ptr) {
bt2.getValue(&Estado_dual);
if (Estado_dual) {
else {
void Funcion_bt3(void *ptr) {
bt3.getValue(&Estado_dual);
if (Estado_dual) {
else {
void Funcion_bt4(void *ptr) {
bt4.getValue(&Estado_dual);
if (Estado_dual) {
else {
void Funcion_bt5(void *ptr) {
bt5.getValue(&Estado_dual);
if (Estado_dual) {
else {
{ uint32_t Estado_dual;/* Consigo el valor del estado del componente. */
bt6.getValue(&Estado_dual);
while (1) {
delay (500);
delay (500);
