Arduino Uno I2C with (motorshield) in Matlab
Little background:
I am working on a project to run 2 stepper motors simultaneously using Matlab. I was able to run the 2 motors in Matlab using an Uno and a motorshield (after uploading the srv.pde. The srv.pde is required for the shield to work in my case.), but I wasn't able to run the motors simultaneously.
I tried I2C with an another Uno and using the Wire library (http://arduino.cc/en/Tutorial/MasterWriter) in addition to the AccelStepper library, I was able to run the motors simultaneously using the Arduino 1.0.2 software.
My question is:
Is there a way of adding the Wire and AccelStepper libraries to the srv.pde so that I can use I2C and AccelStepper in Matlab? Is there another way of running 2 motors simultaneously using Matlab?
Thank you.
Which you aren't going to show us. Fine. Be that way.
Could be. I can't see what code you are using, though, so I can't help.
Attached is the srv.pde code (MATLAB Support Package for Arduino (aka ArduinoIO Package)).
(http://www.mathworks.com/matlabcentral/fileexchange/32374-matlab-support-package-for-arduino-aka-arduinoio-package)
srv_arduino2.pde (32.5 KB)
You might try attaching your code. Click on 'Additional Options...' under the text input box.
Servo servo[70];
An array of 70 servo objects. Why? You can't possibly connect 70 servos to one Arduino.
I have tried to add the Wire library to the srv.pde to establish an I2C,
The slave code:
#include <Wire.h>
Wire.begin(100);
Wire.onReceive(receiveEvent);
void receiveEvent( int howMany)
while (Wire.available())
The master code, is the srv.pde and I added:
#include <Wire.h>
#include <AccelStepper.h>
and to the void loop(), I added
Wire.beginTransmission (100);
Do I need to end the transmission (I mean add Wire.endTransmission() to the code)? Or the transmission should automatically end when I disconnect the arduino?
Adding #include <AccelStepper.h> to the code didn't seem to have an effect, the 2 motors still don't run simultaneously. What do I have to do to fix this?
