Arduino Uno keeps restarting at random times
Good evening,
I am using Arduino Uno with GY-87. I have been struggling with it for couple of days now.. I changed the sensor modules, but still get the same issue: Arduino Uno restarts at random times.
I have 3.3V, GND, SCL and SDA connected.
Thank you.
#include <Wire.h>               //Include the Wire.h library so we can communicate with the gyro
//Declaring Global Variables
byte lowByte, highByte, type, gyro_address, error, clockspeed_ok;
byte channel_1_assign, channel_2_assign, channel_3_assign, channel_4_assign;
byte roll_axis, pitch_axis, yaw_axis;
byte  gyro_check_byte;
int address, cal_int, loop_counter;
unsigned long zero_timer, timer, timer_1, timer_2, timer_3, timer_4, current_time;
float gyro_pitch, gyro_roll, gyro_yaw, angle_pitch, angle_roll;
int acc_y, acc_x, acc_z;
float gyro_roll_cal, gyro_pitch_cal, gyro_yaw_cal;
int temperature;
  Wire.begin();             //Start the I2C as master
  Serial.begin(57600);      //Start the serial connetion @ 57600bps
  delay(250);               //Give the gyro time to start
  intro();
  Serial.println(F(""));
  Serial.println(F("==================================================="));
  Serial.println(F("System check"));
  Serial.println(F("Checking I2C clock speed."));
  TWBR = 12;                      //Set the I2C clock speed to 400kHz.
  #if F_CPU == 16000000L          //If the clock speed is 16MHz include the next code line when compiling
    clockspeed_ok = 1;            //Set clockspeed_ok to 1
  #endif                          //End of if statement
  if(TWBR == 12 && clockspeed_ok){
    Serial.println(F("I2C clock speed is correctly set to 400kHz."));
  else{
    Serial.println(F("I2C clock speed is not set to 400kHz. (ERROR 8)"));
    error = 1;
  gyro_address = 0x68;
  address =  gyro_address;
  delay(3000);
  Serial.println(F("Gyro register settings"));
  start_gyro(); //Setup the gyro for further use
  //If the gyro is found we can setup the correct gyro axes.
  if(error == 0){
    delay(3000);
    Serial.println(F("Gyro calibration"));
    Serial.println(F("Don't move the quadcopter!! Calibration starts in 3 seconds"));
    delay(3000);
    Serial.println(F("Calibrating the gyro, this will take +/- 8 seconds"));
    Serial.print(F("Please wait"));
    //Let's take multiple gyro data samples so we can determine the average gyro offset (calibration).
    for (cal_int = 0; cal_int < 2000 ; cal_int ++){              //Take 2000 readings for calibration.
      if(cal_int % 100 == 0)Serial.print(F("."));                //Print dot to indicate calibration.
      gyro_signalen();                                           //Read the gyro output.
      gyro_roll_cal += gyro_roll;                                //Ad roll value to gyro_roll_cal.
      gyro_pitch_cal += gyro_pitch;                              //Ad pitch value to gyro_pitch_cal.
      gyro_yaw_cal += gyro_yaw;                                  //Ad yaw value to gyro_yaw_cal.
      delay(4);                                                  //Wait 3 milliseconds before the next loop.
    //Now that we have 2000 measures, we need to devide by 2000 to get the average gyro offset.
    gyro_roll_cal /= 2000;                                       //Divide the roll total by 2000.
    gyro_pitch_cal /= 2000;                                      //Divide the pitch total by 2000.
    gyro_yaw_cal /= 2000;                                        //Divide the yaw total by 2000.
    //Show the calibration results
    Serial.print(F("Axis 1 offset="));
    Serial.println(gyro_roll_cal);
    Serial.print(F("Axis 2 offset="));
    Serial.println(gyro_pitch_cal);
    Serial.print(F("Axis 3 offset="));
    Serial.println(gyro_yaw_cal);
    Serial.println(F("Gyro axes configuration"));
    //Detect the left wing up movement
    Serial.println(F("Lift the left side of the quadcopter to a 45 degree angle within 10 seconds"));
    //Check axis movement
    check_gyro_axes(1);
    if(error == 0){
      Serial.println(F("OK!"));
      Serial.print(F("Angle detection = "));
      Serial.println(roll_axis & 0b00000011);
      if(roll_axis & 0b10000000)Serial.println(F("Axis inverted = yes"));
      else Serial.println(F("Axis inverted = no"));
      Serial.println(F("Put the quadcopter back in its original position"));
      waitForSerial();
      //Detect the nose up movement
      Serial.println(F("Lift the nose of the quadcopter to a 45 degree angle within 10 seconds"));
      check_gyro_axes(2);
    if(error == 0){
      Serial.println(pitch_axis & 0b00000011);
      if(pitch_axis & 0b10000000)Serial.println(F("Axis inverted = yes"));
      waitForSerial();
      //Detect the nose right movement
      Serial.println(F("Rotate the nose of the quadcopter 45 degree to the right within 10 seconds"));
      check_gyro_axes(3);
    if(error == 0){
      Serial.println(yaw_axis & 0b00000011);
      if(yaw_axis & 0b10000000)Serial.println(F("Axis inverted = yes"));
      waitForSerial();
  if(error == 0){
    Serial.println(F("Final setup check"));
    if(gyro_check_byte == 0b00000111){
      Serial.println(F("Gyro axes ok"));
    else{
      Serial.println(F("Gyro exes verification failed!!! (ERROR 7)"));
      error = 1;
  Serial.println(F("Gyro set up complete!"));
  zero_timer = micros();
  while(1){
    while(zero_timer + 4000 > micros());                                                  //Start the pulse after 4000 micro seconds.
    //Let's get the current gyro data.
    gyro_signalen();
    //Gyro angle calculations
    //0.0000611 = 1 / (250Hz / 65.5)
    angle_pitch += gyro_pitch * 0.0000611;                                           //Calculate the traveled pitch angle and add this to the angle_pitch variable.
    angle_roll += gyro_roll * 0.0000611;                                             //Calculate the traveled roll angle and add this to the angle_roll variable.
    //0.000001066 = 0.0000611 * (3.142(PI) / 180degr) The Arduino sin function is in radians
    float tmp = angle_pitch - angle_roll * sin(gyro_yaw * 0.000001066);                  //If the IMU has yawed transfer the roll angle to the pitch angel.
    angle_roll += angle_pitch * sin(gyro_yaw * 0.000001066);                  //If the IMU has yawed transfer the pitch angle to the roll angel.
    angle_pitch = tmp;
    //We can't print all the data at once. This takes to long and the angular readings will be off.
    if(loop_counter == 0)Serial.print("Pitch: ");
    if(loop_counter == 1)Serial.print(angle_pitch);
    if(loop_counter == 2)Serial.print(" Roll: ");
    if(loop_counter == 3)Serial.print(angle_roll);
    if(loop_counter == 4)Serial.print(" Yaw: ");
    if(loop_counter == 5)Serial.println(gyro_yaw / 65.5);
    if(loop_counter == 6)Serial.print(" Temperature: ");
    if(loop_counter == 7)Serial.println(temperature / 340.00 + 36.53);
    if(loop_counter == 8)Serial.print(" Acc x: ");
    if(loop_counter == 9)Serial.println(acc_x);
    if(loop_counter == 10)Serial.print(" Acc y: ");
    if(loop_counter == 11)Serial.println(acc_y);
    if(loop_counter == 12)Serial.print(" Acc z: ");
    if(loop_counter == 13)Serial.println(acc_z);
    loop_counter ++;
    if(loop_counter == 60)loop_counter = 0;
//Intro subroutine
void intro(){
  delay(1500);
  Serial.println(F("MPU6500 set up"));
  Serial.println(F("Jasma"));
  delay(1500);
  Serial.println(F("Have fun!"));
void start_gyro(){
  //Setup the MPU-6500
  Wire.beginTransmission(address);                             //Start communication with the gyro
  Wire.write(0x6B);                                            //PWR_MGMT_1 register
  Wire.write(0x00);                                            //Set to zero to turn on the gyro
  Wire.endTransmission();                                      //End the transmission
  Wire.write(0x6B);                                            //Start reading @ register 28h and auto increment with every read
  Wire.requestFrom(address, 1);                                //Request 1 bytes from the gyro
  while(Wire.available() < 1);                                 //Wait until the 1 byte is received
  Serial.print(F("Register 0x6B is set to:"));
  Serial.println(Wire.read(),BIN);
  Wire.write(0x1B);                                            //GYRO_CONFIG register
  Wire.write(0x08);                                            //Set the register bits as 00001000 (500dps full scale)
  Wire.beginTransmission(address);                             //Start communication with the gyro (adress 1101001)
  Wire.write(0x1B);                                            //Start reading @ register 28h and auto increment with every read
  Serial.print(F("Register 0x1B is set to:"));
  Wire.beginTransmission(address);                        //Start communication with the address found during search.
  Wire.write(0x1C);                                            //We want to write to the ACCEL_CONFIG register (1A hex)
  Wire.write(0x10);                                            //Set the register bits as 00010000 (+/- 8g full scale range)
  Wire.endTransmission();                                      //End the transmission with the gyro
  Wire.write(0x1C);                                            //Start reading @ register 28h and auto increment with every read
  Serial.print(F("Register 0x1C is set to:"));
void gyro_signalen(){
  Wire.write(0x3b);                                            //Start reading @ register 43h and auto increment with every read
  Wire.requestFrom(address,14);                                 //Request 6 bytes from the gyro
  while(Wire.available() < 14);                                 //Wait until the 6 bytes are received
  acc_x = Wire.read()<<8|Wire.read();
  acc_y = Wire.read()<<8|Wire.read();
  acc_z = Wire.read()<<8|Wire.read();
  temperature = Wire.read()<<8|Wire.read();                            //Add the low and high byte to the temperature variable
  gyro_roll=Wire.read()<<8|Wire.read();                        //Read high and low part of the angular data
  if(cal_int == 2000)gyro_roll -= gyro_roll_cal;               //Only compensate after the calibration
  gyro_pitch=Wire.read()<<8|Wire.read();                       //Read high and low part of the angular data
  if(cal_int == 2000)gyro_pitch -= gyro_pitch_cal;             //Only compensate after the calibration
  gyro_yaw=Wire.read()<<8|Wire.read();                         //Read high and low part of the angular data
  if(cal_int == 2000)gyro_yaw -= gyro_yaw_cal;                 //Only compensate after the calibration
//Check if the angular position of a gyro axis is changing within 10 seconds
void check_gyro_axes(byte movement){
  byte trigger_axis = 0;
  float gyro_angle_roll, gyro_angle_pitch, gyro_angle_yaw;
  //Reset all axes
  gyro_angle_roll = 0;
  gyro_angle_pitch = 0;
  gyro_angle_yaw = 0;
  gyro_signalen();
  timer = millis() + 10000;
  while(timer > millis() && gyro_angle_roll > -30 && gyro_angle_roll < 30 && gyro_angle_pitch > -30 && gyro_angle_pitch < 30 && gyro_angle_yaw > -30 && gyro_angle_yaw < 30){
    gyro_signalen();
    gyro_angle_roll += gyro_roll * 0.0000611;          // 0.0000611 = 1 / 65.5 (LSB degr/s) / 250(Hz)
    gyro_angle_pitch += gyro_pitch * 0.0000611;
    gyro_angle_yaw += gyro_yaw * 0.0000611;
    delayMicroseconds(3700); //Loop is running @ 250Hz. +/-300us is used for communication with the gyro
  //Assign the moved axis to the orresponding function (pitch, roll, yaw)
  if((gyro_angle_roll < -30 || gyro_angle_roll > 30) && gyro_angle_pitch > -30 && gyro_angle_pitch < 30 && gyro_angle_yaw > -30 && gyro_angle_yaw < 30){
    gyro_check_byte |= 0b00000001;
    if(gyro_angle_roll < 0)trigger_axis = 0b10000001;
    else trigger_axis = 0b00000001;
  if((gyro_angle_pitch < -30 || gyro_angle_pitch > 30) && gyro_angle_roll > -30 && gyro_angle_roll < 30 && gyro_angle_yaw > -30 && gyro_angle_yaw < 30){
    gyro_check_byte |= 0b00000010;
    if(gyro_angle_pitch < 0)trigger_axis = 0b10000010;
    else trigger_axis = 0b00000010;
  if((gyro_angle_yaw < -30 || gyro_angle_yaw > 30) && gyro_angle_roll > -30 && gyro_angle_roll < 30 && gyro_angle_pitch > -30 && gyro_angle_pitch < 30){
    gyro_check_byte |= 0b00000100;
    if(gyro_angle_yaw < 0)trigger_axis = 0b10000011;
    else trigger_axis = 0b00000011;
  if(trigger_axis == 0){
    error = 1;
    Serial.println(F("No angular motion is detected in the last 10 seconds!!! (ERROR 4)"));
  if(movement == 1)roll_axis = trigger_axis;
  if(movement == 2)pitch_axis = trigger_axis;
  if(movement == 3)yaw_axis = trigger_axis;
void waitForSerial(){
  Serial.println(F("Enter any symbol"));
  while(Serial.available()){Serial.read();}
  while (!Serial.available()) { }
  Serial.read();
  //Serial.println(Serial.read());
Can you post an annotated schematic showing exactly how you have wired it? Be sure to show all power, ground, connections and power sources. Give links to technical information on what you are using, We have the UNO.
Consider using the F macro to print also inside loop()
This may fail when micros() overflows or rolls over to 0.
Try
while(4000 > micros()-zero_timer);
instead. There is plenty of information about this, such as in https://www.norwegiancreations.com/2018/10/arduino-tutorial-avoiding-the-overflow-issue-when-using-millis-and-micros/
And remember that what Serial.print() does is to send characters to the UART buffer that takes them one by one at the baud rate you chose. It does not wait for the output to be actually printed. If your process is fast enough the UART buffer fills up and the MCU will have wait for it to have enough room for additional characters and then continue. So if timing is an issue you can space the prints by a specific, controlled interval. The way you are doing it does not guarantee there will be no delays.
Image is from here.
I was connecting either 5V or 3.3V.
I ended up changing not only MPU6050, but also changed Arduino Uno itself and it helped. It might have been some damage done to it before I guess..
Thank you for the information. I implemented it.
And as I mentioned in the previous post, it was hardware issues....
Thanks for letting us know. You can mark it solved if you want.
