Arduino Uno L led Always blinking
Hi to all, I am new to arduino and just bought my first arduino uno, but when I tried to plug it, the L led is always blinking. When I tried to insert a led into no. 13 and ground, it syncs with the blinking of the L led. I cant also upload a program to it.
Is my board damaged?
The blink is normal. You just need to get the upload working,
Please do this:
  • File > Preferences > Show verbose output during: > compilation (uncheck) > upload (check) > OK
  • Sketch > Upload
  • After the process fails you'll see a button on the right side of the orange bar "Copy error messages". Click that button.
  • Paste the error messages in a reply here USING CODE TAGS (</> button on the toolbar).
Aldren:
You did use a current limiting resistor, right?
pert:
Please do this:
  • Sketch > Upload
Thank you for your attention.
Here is the error code in after my uploading.
Sketch uses 928 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM1 -b115200 -D -Uflash:w:C:\Users\admin\AppData\Local\Temp\arduino_build_691577/sketch_nov16a.ino.hex:i
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM1
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x30
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x30
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x30
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x30
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x30
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x30
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x30
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x30
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x30
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x30
avrdude done. Thank you.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
I also noticed that in my device drivers the arduino driver is not installed. Could the problem be from not proper installation?
Im really sorry but Im still learning on this ang I just got my arduino board.
(deleted)
Most Arduinos come pre-loaded with the blink sketch, so the blinking can be considered normal.
COM1 is usually not the Arduino. If it is the Arduino, it will disappear of you disconnect the Arduino. If there are no other ports to choose from in the IDE, check what device manager has to say about it.
Thank you all for your attention. I just downloaded a driver and changed com1 port to com3. It finally worked.
