Hello, can some one help me to troubleshooting my project?
My project uses PID method to keep temperature stable and set interval to display its sensor reading, problem is serial print and lcd won't update reading data from sensor after a while, when my project restarts, update reading comes back and crashes after a while. What should i do? thanks
this is the code i made:
#include <max6675.h>
#include <SPI.h>
#include <Wire.h>
#include <LiquidCrystal_PCF8574.h>
LiquidCrystal_PCF8574 lcd(0x3f);
#include "HX711.h"
// LOAD CELL
HX711 scale;
float calibration_factor = 23.5;
int units;
float ounces;
#define DOUT A1
#define CLK A0
// THERMOCOUPLE
int thermo_so_pin = 10;
int thermo_cs_pin = 12;
int thermo_sck_pin = 13;
MAX6675 thermocouple(thermo_sck_pin, thermo_cs_pin, thermo_so_pin);
//PID
float SV, PV;
int MV, start;
float PVf, PVf_1, fc, RC, a;
float ut, ut_1;
float et, et_1, eint, eint_1, eint_update, edif;
float Kp, Ti, Td, Ki, Kd, PID, P, I, D;
unsigned long t;
double t_1, Ts;
float interval_elapsed, interval_limit;
//LCD
byte pic_termo[8] = //icon termometer
B00100,
B01010,
B01010,
B01110,
B01110,
B11111,
B11111,
B01110,
byte pic_massa[] = { //icon neraca
B11111,
B01010,
B01010,
B10001,
B10111,
B11111,
B11111,
B11111
//DRIVER PEMANAS
int AC_LOAD = 5;
int dimming = 128;
//PUSH BUTTON
const int start_btn = 4;
const int berat_btn = 3;
int berat_cabe;
bool lock_berat = true;
float berat_save = 0;
float berat30p = 0;
//LOAD CELL
scale.begin(DOUT, CLK);
scale.set_scale();
scale.tare();
long zero_factor = scale.read_average();
//FILTER DIGITAL
fc = 3.6;
RC = 1 / (6.28 * fc);
Ts = 0.001;
a = RC / Ts;
PVf_1 = 0;
//PARAMATER KENDALI
Kp = 16.68;
Ti = 1386;
Td = 47.8;
Ki = Kp / Ti;
Kd = Kp * Td;
//LCD DISPLAY
Wire.setClock(10000);
interval_elapsed = 0;
interval_limit = 5;
lcd.begin(16, 2);
lcd.setBacklight(255);
lcd.createChar(1, pic_termo);
lcd.createChar(2, pic_massa);
lcd.setCursor(0, 0);
lcd.write(1);
lcd.print(" ");
lcd.setCursor(8, 0);
lcd.print((char)223);
lcd.print("C");
lcd.setCursor(0, 1);
lcd.write(2);
lcd.print(" ");
t = 0;
//INISIALISASI PIN
pinMode(start_btn, INPUT_PULLUP); //START BUTTON
pinMode(berat_btn, INPUT_PULLUP); //PILIH BERAT BUTTON
pinMode(A2, OUTPUT); //BUZZER
pinMode(7, OUTPUT); //RELAY AC
pinMode (6, OUTPUT); //RELAY DC
pinMode(AC_LOAD, OUTPUT); //OUTPUT KENDALI
attachInterrupt(0, zero_crosss_int, RISING); //ZERO CROSSING DRIVER PEMANAS
pinMode(start_btn, HIGH);
//Z-C DRIVER PEMANAS
void zero_crosss_int() {
int dimtime = (75 * dimming);
delayMicroseconds(dimtime);
digitalWrite(AC_LOAD, HIGH);
delayMicroseconds(10);
digitalWrite(AC_LOAD, LOW);
beratcabe();
load_cell();
//START BUTTON
start = digitalRead(start_btn);
if (start == 1) {
SV = 70;
digitalWrite(7, LOW);
digitalWrite(6, LOW);
lock_berat = true;
if (units <= berat30p) {
analogWrite(A2, 1023);
else if (start == 0) {
SV = 0;
digitalWrite(7, HIGH);
digitalWrite(6, HIGH);
analogWrite(A2, 0);
suhu();
t_1 = t;
t = millis();
Ts = (t - t_1) / 1000;
// PERHIUTNGAN PID
et = SV - PVf;
eint_update = ((et + et_1) * Ts) / 2;
eint = eint_1 + eint_update;
edif = (et - et_1) / Ts;
PID = Kp * et + Ki * eint + Kd * edif;
PID = PID / 1;
if (PID > 255) {
PID = 255;
else if (PID < 0) {
PID = 0;
//OUTPUT KENDALI KE DRIVER PEMANAS
dimming = map(PID, 0, 255, 80, 0);
// MENAMPILKAN DATA KE LCD
interval_elapsed = interval_elapsed + Ts;
if (interval_elapsed >= interval_limit) {
lcd.setCursor(2, 0);
lcd.print(PVf);
lcd.print(" ");
lcd.setCursor(2, 1);
lcd.print(units);
Serial.print(70);
Serial.print(" / ");
Serial.println(PVf);
else {
interval_elapsed = interval_elapsed;
void beratcabe() {
//PILIH INPUT BERAT CABAI
berat_cabe = digitalRead(berat_btn);
if (berat_cabe == 1) {
lcd.setCursor(5, 1);
lcd.print(" / 500 g");
} else if (berat_cabe == 0) {
lcd.setCursor(6, 1);
lcd.print(" / 1000 g");
void load_cell() {
//PEMBACAAN BERAT CABAI
scale.set_scale(calibration_factor);
units = scale.get_units(), 10;
if (units < 0)
units = 0.00;
if (lock_berat == true) {
berat_save = units;
berat30p = berat_save * 0.3;
lock_berat = false;
void suhu() {
//FILTER DIGITAL THERMOCOUPLE
PV = thermocouple.readCelsius();
PVf = (PV + a * PVf_1) / (a + 1);
PVf_1 = PVf;
