Hello,
is it possible to Use the lcd1602 Display, a RTC, a SD-Card Module and 1 Pin as a Input Pin, on the Arduino Uno?
I do not have a Code jet. Right now im just curiouse and would probably save some time on this Project, by knowing this.
Hello,
Yes it is. However, it may not be able to do the task that you want it to do, that you're not telling us about.
aarg:
Sorry.
So. The Arduino need to count by 1, every time it gets a signal from the Input Pin. It need to count from 6:00 am to 2:30 pm (S1).Then switch the Row on the Display and count from 2:30 pm till 10:00 pm (S2). And it should subtract it for the Calender Week. Should Display the last Calender Week and the current Calender Week.
So every time it gets turned off after 10 pm and then get turned on at 6 am it should be ready to count it again. Thats what the rtc is needed for.
So after the Week you should get the Data out of the sd-card and put it onto Excel. The Display is more or less just for the astetics. So if you walk by, you can just look real quick at it to see how far it has come.
And i want it to display it like this:
S1: xxx Calender Week (CWx): xxxx
S2: xxx Calender Week (CWx): xxxx
