Arduino Uno Lesson 5 Digital Switch
I am trying to use a single button/switch to turn an LED ON/OFF (like a light switch at home ) , but i am having trouble finding code that would execute that. Does anyone know how it could possibly work?
Here is the exactly what you want. Arduino - Button control LED
The code in that tutorial work not only for button but switch
you want the LED to toggle with each button press, right?
// recognize multiple button presses; tgl LED when pressed
byte butPin = A1;
byte ledPin = 10;
byte butLst;
void setup (void)
    digitalWrite (ledPin, HIGH);
    pinMode      (ledPin, OUTPUT);
    pinMode      (butPin, INPUT_PULLUP);
    butLst      = digitalRead (butPin);
void loop (void)
    byte but = digitalRead (butPin);
    if (butLst != but)  {
        butLst = but;
        if (LOW == but)     // button pressed
            digitalWrite (ledPin, ! digitalRead (ledPin));
    delay (10);         // debounce
gcjr:
byte butPin = A1;
byte ledPin = 10;
byte butLst;
void setup (void)
void loop (void)
        butLst = but;
thanks gcjr that totally worked !
@gcjr
the code you posted worked as I needed ! but would you mind explaining the code or providing some pseudocode to help me understand what is going on ? Im trying to learn Arduino so it would be of much help .
Anyone else is welcome to help explain btw !
