Arduino Uno light up led's 1 by 1 by clicking
So I am new to Arduino, so I wanted to try this function.
Basicly as the title states I want it that when I press a button that 1 led turn on and when I press again the next led turn on and the old one goes off. In total I have 3 led’s. I already wrote some code but when I press the button sometimes it takes 4 to 5 clicks eventhough I put a short delay.
EDIT: Posted entire code!
#include <Arduino.h>
const int PIN_LED_RED = 4;
const int PIN_LED_GREEN = 5;
const int PIN_LED_BLUE = 6;
const int PIN_LED_YELLOW = 7;
const int PIN_BUTTON_1 = 8;
const int PIN_BUTTON_2 = 9;
int buttonState_1 = 0;
  pinMode(PIN_LED_RED, OUTPUT);
  pinMode(PIN_LED_GREEN, OUTPUT);
  pinMode(PIN_LED_BLUE, OUTPUT);
  pinMode(PIN_LED_YELLOW, OUTPUT);
  pinMode(PIN_BUTTON_1, INPUT_PULLUP);
  pinMode(PIN_BUTTON_2, INPUT_PULLUP);
  buttonState_1 = digitalRead(PIN_BUTTON_1);
  if (buttonState_1 == LOW)
    digitalWrite(PIN_LED_RED, HIGH);
    delay(150);
    digitalWrite(PIN_LED_RED, LOW);
    delay(150);
  while (digitalRead(PIN_BUTTON_1) == LOW)
    digitalWrite(PIN_LED_GREEN, HIGH);
    delay(150);
    digitalWrite(PIN_LED_GREEN, LOW);
Kudos for posting code correctly the first time.
'functions weird' is not a problem description. Describe exactly the behavior you are seeing - since the forum cannot.
The problem could well lie in the code not posted. Edit the original post to include the entire sketch.
What do you mean by weird ?
How is your input button wired ?
Is it in a known state at all times or, when the button is not pressed is it floating at an unknown, possibly HIGH, possibly LOW state ?
You need to detect when the button becomes pressed, not when it is pressed. The StateChangeDetection example in the IDE shows how to do it
