I'm quite new to the Arduino Board and programming on Microcontrollers.
I wrote a little script to control a little trafficlight circuit. But while not having finished the loop the current glowing LED shuts off, the "L"-Led flashs a few times, then turns back on and the loop of my script restarts.
Thanks for your help guys
Greets
#define DELAY1 10000
#define DELAY2 2000
#define DELAY3 3000
int ledPinRed = 7;
int ledPinYellow= 6;
int ledPinGreen= 5;
void setup(){
 pinMode(ledPinRed, OUTPUT);
 pinMode(ledPinYellow, OUTPUT);
 pinMode(ledPinGreen, OUTPUT);
 digitalWrite(ledPinRed, LOW); //GreenPhase
 digitalWrite(ledPinYellow, LOW);
 digitalWrite(ledPinGreen, HIGH);
 delay(DELAY1);
  digitalWrite(ledPinYellow,HIGH); //YellowPhase
  digitalWrite(ledPinGreen,LOW);
 delay(DELAY3);
  digitalWrite(ledPinRed, HIGH); //RedPhase
  digitalWrite(ledPinYellow,LOW);
 delay(DELAY1);
  digitalWrite(ledPinYellow, HIGH ); //RedYellowphase
 delay(DELAY2);
No offence guys, but to clarify this.
I had the same problem with other circuits i built. So i guess the problem originates from the Board. And not by my project itself.
My project does what it'S supposed to. But it gets interrupted by the error i explained.
After some time the temporarily LED turns off without being implemented.
The Error imo seemed to be that the Board somehow resets / restarts itself after approx. 30 seconds.
I'm not looking for any error in the scematic(besides the ground i missplaced there.[and the colour of the LEDs i didn't find cause it was my first scetch with Fritzing]]) which is why i originally didn't post the code and the Circuit.
I hope this showed what i am having problems with.
Sincerely Tilo
The most likely cause of the board resetting is your circuit (excessive current causing a reset). Disconnect your stuff from the Arduino and then see if the board will operate without resetting. If it does work without resetting troubleshoot and correct your circuit. If it resets with nothing connected then the problem is with the board or power to the board. If you are using a 9v battery try using a 9v power supply.
You should be looking for errors in all aspects of your setup. Lots of people have found that the source of their problem was in some part of the setup that they were sure was OK.
Hence the question about the resistors.
Good point. We shouldn't have to be asking questions that a photograph of the setup would clarify.
Update:
As i plugged it back in today it works without getting interrupted.
I don't know what supposedly could've changed from yesterday.
Anyway thanks guys :).
I will try to figure out how this could've happened and keep you updated if you are interested.
Greets
Update 2:
It seems like the problem only comes up after the loop completed 3-4 turns after beeing plugged in
(so my preceding update was wrong).
I have made an video for you guys so you can hopefully tell me what i've wired / setup wrong.
Here a little explanation of the circuit:
I use the digital ports 7-5 as outputs and set their level HIGH to power the LEDs , which are in series with an 330 Ohm resistor so the current is about 15mA.
The board is powered through the USB interface, which should be able to provide the 30 mA which the board max. supplies when 2 LEDs are on.
Try powering it with a wall wart instead. I suspect it's a foible with your operating system powering down the usb port. Do you perchance, have Windows 8.1 on there?
I'm running windows 8 at the moment.
I'll try to switch operating systems and will give you the update if it runs without the interrupt.
EDIT:
I've switched to my Mac Partition and it works just fine now.
Thanks a lot for your help. I'll get myself an external power source now.
Sincerely Tilo
