Hi guys!
I've been searching all day for a solution to my problem and I'm now desperate enough to kindly ask you guys what I'm missing here.
I bought some sticks with 8 WS2812B leds on them. Not from adafruit, but another company.
However I hooked one of them up to a 5V 10A power supply (which actually supplies 5,3V btw) using a 1000µF cap which bridges between the positive output and ground.
Next was a 470Ohm resistor on the data line running from the Arduino Uno/Mega (tried both) to the actual LED stick.
Then I loaded several example programs which come with Adafruit's NeoPixel library and a few of the FastLED-lib's examples but the output stays the same.
A few LED's are changing color all the time whereas others flicker and flash randomly with no pattern at all. Then it settles back to the actual sketch I loaded and a few moments later the first LED ignores every brightness setting and shines to its fullest.
Just a few examples of what is going on when the LEDs are connected ![]()
However as of now two of the three sticks I tried won't turn on anymore.
I tried hooking them up to a LiPo with 3,7V which didn't change anything.
Was reading that I maybe would need a level shifter when using voltage below 3,7V to increase the strenght of the actual data signal.
I found a video on reddit where a guy had exactly the same problem and uploaded it to youtube: ws2812b / arduino issue - YouTube
What exactly am I doing wrong? I read many times that the WS2812B are kinda sensitive but I don't want to wait for a specific moon phase for them to actually work properly and reliably... ![]()
Do you guys have any suggestions of what I could be doing wrong?!
Cheers and thank you ever so much!
Mario
