I have created a Arduino Uno RC Car project with Motor Shield and HC05 Bluetooth Module which is powered by four 9V Batteries. I have done everything correct like the wires are setup appropriately, Motor Shield is fixed properly, all the motors are connected to motor shield properly, Bluetooth is working fine. Code given Below is uploaded Successfully. I can connected to car but as soon as I give it first command all the motors start to move and they never stop unless the batteries are disconnected. I have searched all this forum but not found exact solution for my problem. I am creating a school project and highly rely on this to pass my project. Tried many things but nothing seems to be working. Any efforts for resolving this issue will be appreciated. Thank you. Please forgive If done any mistake while posting to this forum.
//Arduino Bluetooth Controlled Car Video - https://www.youtube.com/watch?v=BbASlFelJSQ //
//// Before uploading the code you have to install the necessary library//
//AFMotor Library https://learn.adafruit.com/adafruit-motor-shield/library-install //
#include <AFMotor.h>
//initial motors pin
AF_DCMotor motor1(1);
AF_DCMotor motor2(2);
AF_DCMotor motor3(3);
AF_DCMotor motor4(4);
char command;
Serial.begin(9600); //Set the baud rate to your Bluetooth module.
void loop(){
if(Serial.available() > 0){
command = Serial.read();
Stop(); //initialize with motors stoped
//Change pin mode only if new command is different from previous.
//Serial.println(command);
switch(command){
case 'F':
forward();
case 'B':
back();
case 'L':
left();
case 'R':
right();
void forward()
motor1.setSpeed(255); //Define maximum velocity
motor1.run(FORWARD); //rotate the motor clockwise
motor2.setSpeed(255); //Define maximum velocity
motor2.run(FORWARD); //rotate the motor clockwise
motor3.setSpeed(255);//Define maximum velocity
motor3.run(FORWARD); //rotate the motor clockwise
motor4.setSpeed(255);//Define maximum velocity
motor4.run(FORWARD); //rotate the motor clockwise
void back()
motor1.run(BACKWARD); //rotate the motor anti-clockwise
motor2.run(BACKWARD); //rotate the motor anti-clockwise
motor3.setSpeed(255); //Define maximum velocity
motor3.run(BACKWARD); //rotate the motor anti-clockwise
motor4.setSpeed(255); //Define maximum velocity
motor4.run(BACKWARD); //rotate the motor anti-clockwise
void left()
void right()
void Stop()
motor1.setSpeed(0); //Define minimum velocity
motor1.run(RELEASE); //stop the motor when release the button
motor2.setSpeed(0); //Define minimum velocity
motor2.run(RELEASE); //rotate the motor clockwise
motor3.setSpeed(0); //Define minimum velocity
motor3.run(RELEASE); //stop the motor when release the button
motor4.setSpeed(0); //Define minimum velocity
motor4.run(RELEASE); //stop the motor when release the button
