Arduino Uno - Nano Step motor code
I used this code at Arduino Uno without problem:
#include <AccelStepper.h>
#include <Wire.h>
#define HALFSTEP 8
#define motorPin1  2     // IN1 on the ULN2003 driver 1
#define motorPin2  3     // IN2 on the ULN2003 driver 1
#define motorPin3  4     // IN3 on the ULN2003 driver 1
#define motorPin4  5     // IN4 on the ULN2003 driver 1
AccelStepper stepper(HALFSTEP, motorPin1, motorPin3, motorPin2, motorPin4);
   stepper.setMaxSpeed(1000);
   stepper.setSpeed(127.7);
   stepper.runSpeed();
Isn't it possible using the same code at Arduino nano? Or should i change something for nano?
PS: I tried it, but it didn't work.
I think that program should work just the same on a Nano.
How are you powering the stepper motor? It should not be powered from the Arduino (either Uno or Nano).
...R
How did it not work? I use Uno and Nano interchangeably with the same code with no problem. I use my own software so I can only suggest it's a problem with AccelStepper, but that doesn't make sense either.
Robin2:
...R
With ULN2003A Step Motor Driver Card.
drkoray:
A motor driver card does not generate electricity. Where is the electricity coming from?
...R
Robin2:
...R
From Arduino 5V and GND.
drkoray:
Did you read all of Reply #1 ?
...R
Robin2:
...R
Of course.
Problem is: The code and step motor work at uno with the same connection schema. When i change uno with nano, motor doesn't work.
Sometimes electronic stuff can work outside of the specification. That doesn't mean it's guaranteed to always work that way! I suspect your Uno can power the stepper motor by operating (temporarily) above it's specified current limit. Your nano on the other hand, has a tighter tolerance, and the motor cannot over-amp it the way it does to the Uno.
Uno and Nano have different voltage regulators.
Uno: NCP1117 series - over 1.0 A
Nano: µA78M05 - up to 500 mA
