Arduino uno not reading switch states
Basically, I have a BLDC motor and ESC controlled by the Arduino uno. I'm using a 3 state switch to control Forward/neutral/reverse. I connected the switch common connection to 5v and the other sides to pins 11 and 12. However, when I run my code, it just constantly loops my first for loop and my switch has no effect. I also have a hall sensor I'm trying to use to stop it so that's why the attachInterrupt is there, but I do not know if that is going to work yet because of the previous problem.
#include <Servo.h>
Servo ESC; // create servo object to control the ESC
boolean CTRL = false;
boolean StateA=false;
boolean StateB=false;
boolean STOP=false;
byte Pos=90;
byte FMax = 180;
byte RMax = 0;
int pos = 0;    // variable to store the servo position
  Serial.begin(57600);
  attachInterrupt(0, magnet_detect, RISING);   //Initialize hall sensor to interrupt pin (digital pin 2)
  // Attach the ESC on pin 9
  ESC.attach(9,1000,2000); // (pin, min pulse width, max pulse width in microseconds)
StateA=digitalRead(11);
StateB=digitalRead(12);
 if (StateA && !CTRL && !STOP){
    for (pos = 90; pos <= 110; pos += 1) { // goes from 90 degrees to 180 degrees
        ESC.write(pos);              // tell motor speed in variable 'pos'
        delay(200);                  // waits 200ms for the servo to reach the position
  CTRL=!CTRL;
 if (StateB && CTRL && !STOP){
     for (pos = 90; pos <= 60; pos -= 1) { // goes from 90 degrees to 0 degrees
  CTRL=!CTRL;
  if (StateA && CTRL && !STOP){
     ESC.write(FMax);
   if (StateB && !CTRL){
      ESC.write(RMax);
   if(!StateA && !StateB) {
      ESC.write(90);
      STOP = false;
   if (STOP) {
      ESC.write(90);
void InterruptSR() {
  STOP = !STOP;
void magnet_detect()   //Function to stop motor once hall sensor detects a magnet
    pos <= 90;
    ESC.write(pos);
Show us a good schematic of your proposed circuit.
Show us a good image of your ‘actual’ wiring.
Give links to components.
I recommend INPUT_PULLUP and connect the switch terminals to GND. Unless you have pulldown resistors the way you have it wired the inputs will float with NC.
A few observations:
  1. When I am beginning a project I write a simple sketch to test each piece of hardware. In this case write 3 sketches: one for the switch, one for the hall effect sensor, and one for the servo. That way when you test your final code you can be sure the hardware and wiring are NOT the problem if it doesn't work.
  2. You do not need an interrupt for the hall effect sensor. I would just recommend reading the sensor at the beginning of loop().
  3. 200ms for the servo to move 1 degree is excessive. 20 degrees of movement will take 4 seconds. 30 degrees will take 6 seconds the way you have it coded. If you really need it move that slow that is fine; however, your program will be completely stalled during these movements, which may or may not be a problem.
I took out the Hall sensor stuff, and tried with just the acceleration code and switches. I added a pull down resistor as well and I get no response at all. Also I know the acceleration code works just fine, I have tested this many times.
#include <Servo.h>
int pos = 90;                               // variable to store the servo position
int stateA = digitalRead(11);               // variables for reading the switches status
int stateB = digitalRead(12);
  ESC.attach(9,1000,2000);                  // (attach to pin 9, min pulse width, max pulse width in microseconds)
if (stateA == LOW) {                       // if swith in forward postion run motor forward a set speed
     for (pos = 90; pos <= 110; pos += 1) { // goes from 0 degrees to 180 degrees
        delay(20);                         // waits 200ms for the servo to reach the position
if (stateB == HIGH) {                     // if switch in rear position run motor backwards at set speed
else {                                   // motor off, mid position
   pos <= 90;
   ESC.write(pos);
Your sketch has multiple errors
try this sketch for testing the switches separately from anything else
trying to be quick by combining too early too many things will turn out to slow you down because there are multiple things that are wrong.
trying this then trying that without knowing it slows you down too
For all future steps take the time to do separated tests and take time to learn the basics.
This will speed up finishing your project
const byte stateA_pin = 11; // use constants for IO-pin NOT direct numbers
const byte stateB_pin = 12;
int stateA;               // variables for reading the switches status
int stateB;
unsigned long myTestTimer;
// helper-function for easy to use non-blocking timing
boolean TimePeriodIsOver (unsigned long &expireTime, unsigned long TimePeriod) {
  unsigned long currentMillis  = millis();
  if ( currentMillis - expireTime >= TimePeriod ) {
    expireTime = currentMillis; // set new expireTime
    return true;                // more time than TimePeriod) has elapsed since last time if-condition was true
  else return false;            // not expired
  Serial.begin(115200); // start serial interface
  Serial.println( F("Setup-Start") );
  pinMode(stateA_pin, INPUT);
  pinMode(stateB_pin, INPUT);
  // reading the switches status must be done INSIDE loop
  stateA = digitalRead(stateA_pin);
  stateB = digitalRead(stateB_pin);
  if ( TimePeriodIsOver(myTestTimer,1000) ) {
    // if 1000 milliseconds = one second have passed by
    Serial.print("digitalRead("); // print title and state of IO-pin to the serial monitor
    Serial.print(stateA_pin);
    Serial.print(")=stateA=");
    Serial.println(stateA);
    Serial.print(stateB_pin);
    Serial.print(")=stateB=");
    Serial.println(stateB);
Be the change you want to see in the world
best regards Stefan
I was able to get this to work first try, So it seems like my problem is with the if statements I made?
With the if statement formatted properly you can see how they are nested. Is this what you intended? Unless stateA==LOW you will never get to the if (stateB == HIGH). These ifs were NOT nested in your original code. This is why properly formatted and indented code is important.
    pos <= 90;
    ESC.write(pos);
That is not what I intended, It was supposed to work if stateA =/= LOW then it moves on to check stateB's condition.
So with this code, it is like you said, it will only go to next if statement when stateA == HIGH. How can I make it progress to the next if statement without needing the first if statement's condition to be met?
#include <Servo.h>
const byte stateA_pin = 10; // use constants for IO-pin NOT direct numbers
const byte stateB_pin = 11;
int stateB;
if (stateA == HIGH) {                       // if swith in forward postion run motor forward a set speed
      for (pos = 90; pos <= 110; pos += 1) { // goes from 90 degrees to 0 degrees
      Serial.print(")=stateB=");        Serial.println(stateB);
      pos <= 90;
      ESC.write(pos);
Why is that in the loop function?
Why print the same state multiple times?
    } // closing curly brace of for-loop
    // if-condition still INSIDE if-condition if (stateA == HIGH) {
    } // closing curly brace of if (stateB == HIGH)
    // else still INSIDE if-condition if (stateA == HIGH) {
      pos <= 90;
      ESC.write(pos);
    } // closing curly brace of else
  } // clsoing curly brace of if (stateA == HIGH) {
well this is one of the rare cases where I'm just asking back
After showing you that your second if-condition is
inside
your first if-condition
What do you think?
best regards Stefan
