Arduino Uno not recognized as port, only unknown device.
Hi, I'm having some trouble with my Arduino Uno board on a windows XP laptop.
I got it working at first and uploaded the "Blink" sketch successfully, but later it disappeared from the COM9 port i was using. When i connect the board it's on and runs the Blink sketch, but in the device manager it only shows up as an unknown device under USB controllers, not Ports(COM&LPT).
I have tried to update drivers for the unknown device with all options through the device manager. The automatic didn't find any drivers. When choosing from a list I browse to ...Programs\arduino\drivers and the guide can't find any "better drivers".
When choosing from specific drivers I can only find "Unknown device" even if I uncheck the compatible drivers box. I've tried clicking on "disk" here and browse to ...programs\arduino\drivers and selecting the arduino file there. none of this got me anywhere.
I have tried running dpinst -x86 without problem but the board is still "unknown device".
I have tried installing the drivers from FDTI, no problem in installation but it didn't help.
Does anyone know what the problem is?
alternatively, i tried to run it on my home computer which has windows 7 64bit. but i couldn't get the drivers right there, i couldn't run dpinst -x86 since it was for 32 bit and i couldn't find Ports(COM&LPT) at all in device manager. As a plan B i can use my home computer if i get that working.
Can you post a link to the board you have? So that we can see what board it is and what usb to serial converter is on it.
It is an Arduino Uno, board model Uno R3 SMD edition. Bought from germany.
The Uno R3 (SMD or otherwise) does not use an FTDI chip, it has an Atmel USB to serial converter.
What version of the IDE have you installed?
The latest available on the site, 1.0.6.
OK. When you try to update the drivers, have you tried:
In device manager select the unknown device, update driver, select all devices, com and LTP, select Arduino, and see what you can find in there?
Yes. On other devices i can get a list of manufacturers to choose drivers from, Arduino LLC included. But on the unknown device this list doesn't appear. Only a list of models with a single entry: unknown device.
I am not on a windows machine at the moment, but you want to select an Uno R3 if it is in the list.
