I just bought my first arduino for a school project. It's an Arduino Uno.
The problem is that my win11 pc can't see the device. It is not in device manager (not other devices or anywhere else). I got a program called USBVIEW and when I plug in the arduino, it's not showing up there.
First I installed IDE, and i found the drivers folder and installed the drivers, but still not working. I'm using the cable that I got with the arduino. I also tried it on my laptop also with win11 and there is the same problem.
It has power when I plug it in. ON lights up, and the LED next to a "L" is blinking slowly.
It will not matter if you install additional drivers from the links I gave you.
Good pictures of your board may also help us.
What is your OS as that can also come into play ?
I have some doubts that it's genuine. Compare your image with the image on Arduino Uno Rev3 — Arduino Official Store. Colour is wrong and the print of the board identification / Arduino logo on the top is missing
That is the Tx LED and it is driven by the 16U2. The fact that your board is not recognised as well makes me think that the 16U2 is not correctly programmed by the manufacturer or is faulty.
If you don't want to ship it back to the seller you can try to program the 16U2 using the Atmel flip program and the 6-pin header close to it. You can find instructions on the web.
Have you tried a different USB cable as previously suggested by @Ballscrewbob? Perhaps you have a power/charge only cable, which only has/uses the 5V and GND wires.
That is one of the Chinese USB cables.
They often fail..
You can pick them up quite easily and cheap in thrift stores from printers and such and they are usually better than the Chinese ones.
I try get the ones with a ferrite core built in.
