Weeks i try to Serial send data from a Cocoa OS X App to my Arduino Uno.
After weeks i found a solution, if i use the Serial File "/dev/cu.usbmodem1a1231" it WORKS!
But, if use "/dev/tty.usbmodem1a1231" it dont works!
I conntct Arduino Uno with USB-Cable.
Does anyone know why the "/dev/cu.usbmodem1a1231" File works, but the "/dev/tty.usbmodem1a1231" File Not Workl?
Thanks alot!
int ledPin = 13;
#include <Servo.h>
Servo meinServo;
int analogPin = 0;
pinMode(ledPin, OUTPUT);
digitalWrite(ledPin, LOW);
meinServo.attach(9);
void loop(){
while (Serial.available()) {
int incomingByte;
incomingByte = Serial.read();
digitalWrite(ledPin,HIGH);
meinServo.write(incomingByte);
delay(20);
this works. But only when i use „/dev/cu.usbmodem1a1231“.
If i try to use „/dev/tty.usbmodem1a1231“ i become it never ever to work. I can open the Port,
but Arduino never receive the Serial Signal.
Im totally confused, can please someone help me?
What is different between „/dev/cu…..“ and „/dev/tty…..“?
All Tutorials and User Codes i can find using the „/dev/tty…..“, why it don’t works for me?
My Tech-Specs:
Arduino Uno R3 (Atmega328)
Connected with USB-Cable to
Macbook Pro with OS X 10.9
X-Code 5.01 for the Objective C App
I really erally would be happy if you can help me, i just freaking out
Hello,
Thank you for answering!
im not sure i understand what you mean.
i can open /dev/tty..... then if i try to send something, arduino nothing receive.. i only close tty, when i close the my objective-c App.
The same Code works if i use /dev/cu.... but it dont works with /dev/tty....
When you open the serial port, you need to wait sufficient time for the arduino to complete its reboot before sending data. That might be your problem.
oh sorry, now i understand, yes i know this and i always wait... i can wait a couple of minutes but nothing... it still not works, i actually nas waitet 5 minutes before send something, but it doesnt work
