Arduino UNO only works on Mac now, not PC
I've had this arduino for about a year now, and I started using it on a PC just fine. Then one day I plugged it into a Mac at some local hackerspace, and used that as my uploading computer. Ever since then, I can't get the thing to work on a PC again. It always gives me this error.
avrdude: stk500_getsync(): not in sync: resp=0x30
I spent a long time trying to troubleshoot it, tried messing with FTID drivers (although I had no real idea what I was doing) and eventually gave up and thought, I'll just go try it once on the mac downstairs.
Low and behold, it worked on my old mac mini. I'm a primarily PC user, with a PC laptop, and just a macmini downstairs for family use so, it's not ideally where I want to be doing my tinkering.
Any ideas as to why it converted my arduino to only working on Mac OS permanently? Thanks.
Strange. Try the loop-back test?
Hmm, just tried that from here Arduino Forum didn't work. Thanks for recommending that though, never had heard of it but it's a good thing to know about for the future.
But! I've found a new lead. When I plug in the USB cable it beeps twice, which I just found out means the correct drivers are not installed. I guess I'll have to delve a little deeper into getting those installed, though I'm on an older PC running XP.
SOLVED: I finally installed new drivers (which I thought I had tried numerous times before and always failed)
http://arduino.cc/it/Guide/Windows#toc4
installed them the correct way this time, and it's running Blink fine.
Finally can start again on projects!
