Arduino UNO output info! PLEASE!
Does a Arduino UNO have enough output voltage and amperes to trip a standard automotive 12v dc relay?
If not what do I need to trip the relay.
I am looking to control multiple relays (4) that would carry higher volts and amps to control a 12 v dc motor.
If the UNO does not have that capability, what would you suggest?
Thank You!
ProStreet1: Does a Arduino UNO have enough output voltage and amperes to trip a standard automotive 12v dc relay?
It has neither the volts nor the amps. The max voltage from an Arduino I/O pin is 5v and the max safe current is about 20 milliamps.
You need to get the Arduino to switch a small transistor which, in turn, switches the 12v power for the relay coil.
...R
There are many ways to drive a load with the Arduino.
Here are some examples:
