Arduino Uno P1 meter serial read to URL GET
I made a solution to readout the P1 meter (electra power system). The P1 meter gives every 10 seconds a message (telegram). This is inverted by a 7404 IC and connected to port d0 (RX) of the Arduino Uno.
When i readout the RX port with serial monitor it works perfect.
Not all info from the telegram is usefull, so i filter info i want and put it in a variable.
All this is working perfect.
Every 5 minutes the values are send to a url with the GET methode. The url is hosted on my Raspberry and been read out with PHP to insert in the SQLite database.
This works also.
But when it all works for about >15 hours it stops.
Is my Arduino Uno to small for this?
Can anybody tweak my code?
/* Arduino 'slimme meter' P1-port reader.
 serial poort gebruiken pin 0)
//#include <AltSoftSerial.h>
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = {
  0x00,0x40,0xad,0x95,0x4f,0x34};
//  0xDE, 0xAD, 0xBE, 0x30, 0x32, 0x31};
IPAddress ip(192,168,254,15);
IPAddress server(192,168,254,11);
EthernetClient client;
const int requestPin =  5;
char input; // incoming serial data (byte)
bool readnextLine = false;
#define BUFSIZE 75
char buffer[BUFSIZE]; //Buffer for serial data to find \n .
int bufpos = 0;
long mEVLT = 0; //Meter reading Electrics - consumption low tariff
long mEVHT = 0; //Meter reading Electrics - consumption high tariff
long mEAV = 0;  //Meter reading Electrics - Actual consumption
long mG = 0;   //Meter reading Gas
long TmEVLT =0;
long TmEVHT =0;
long TmEAV =0;
long PmEVLT = 1; //Meter reading Electrics - consumption low tariff
long PmEVHT = 1; //Meter reading Electrics - consumption high tariff
long PmEAV = 1;  //Meter reading Electrics - Actual consumption
long PmG = 1;   //Meter reading Gas
long PTmEVLT =1;
long PTmEVHT =1;
long PTmEAV =1;
long lastTime = 0;               // will store last time
long interval = 60000*5;         // (60000 = minuut * aantal / interval at which to blink (milliseconds)
//long interval = 10000;
  Ethernet.begin(mac, ip);
  decodeTelegram();
Serial.print("mEVLT Laag tarief : ");
Serial.print(mEVLT);
Serial.println(" Watt");
Serial.print("mEVHT Hoog tarief: ");
Serial.print(mEVHT);
Serial.print("TmEVLT zonnepaneel Laag tarief : ");
Serial.print(TmEVLT);
Serial.print("TmEVHT Zonnepaneel Hoog tarief: ");
Serial.print(TmEVHT);
Serial.print("mEAV Actueel : ");
Serial.print(mEAV);
Serial.print("TmEAV Zonnepaneel Actueel : ");
Serial.print(TmEAV);
Serial.print("Gas : ");
Serial.print(mG);
Serial.println(" m2");
    decodeTelegram();
                      // controleer of er 0 waarden zijn geraporteerd. Zoja, dan is de vorige waarde geldig
//    if(mEVLT>0){
      PmEVLT=mEVLT;
//        if(mEVHT>0){
      PmEVHT=mEVHT;
//        if(TmEVLT>0){
      PTmEVLT=TmEVLT;
//        if(TmEVHT>0){
      PTmEVHT=TmEVHT;
//        if(mEAV>0){
      PmEAV=mEAV;
//        if(TmEAV>0){
      PTmEAV=TmEAV;
//       if(mG>0){
      PmG=mG;
                            // zend na de intervaltijd de gegevens naar de RPi
  if(millis() - lastTime > interval) {
    lastTime = millis();
    //send data to PHP/MySQL
    httpRequest();
    //Stop Ethernet
    client.stop();
} //Einde loop
void decodeTelegram() {
//  Serial.println("Open telegram p1 poort");
  long tl = 0;
  long tld =0;
  if (Serial.available()) {
    input = Serial.read();
    char inChar = (char)input;
    // Fill buffer up to and including a new line (\n)
    buffer[bufpos] = input&127;
    bufpos++;
    if (input == '\n') { // We received a new line (data up to \n)
      if (sscanf(buffer,"1-0:1.8.1(%ld.%ld" ,&tl, &tld)==2){
        tl *= 1000;
        tl += tld;
        mEVLT = tl;
//    Serial.print("mEVLT Laag tarief : ");
//    Serial.print(mEVLT);
//    Serial.println(" Watt");
      // 1-0:1.8.2 = Elektra verbruik hoog tarief (DSMR v4.0)
      if (sscanf(buffer,"1-0:1.8.2(%ld.%ld" ,&tl, &tld)==2){
//      Serial.println("mEVHT gevonden");
        tl *= 1000;
        tl += tld;
        mEVHT = tl;
//    Serial.print("mEVHT Hoog tarief: ");
//    Serial.print(mEVHT);
      // 1-0:2.8.1 = Elektra verbruik laag tarief (DSMR v4.0)
      if (sscanf(buffer,"1-0:2.8.1(%ld.%ld" ,&tl, &tld)==2){
        tl *= 1000;
        tl += tld;
        TmEVLT = tl;
//    Serial.print("TmEVLT zonnepaneel Laag tarief : ");
//    Serial.print(TmEVLT);
      // 1-0:2.8.2 = Elektra verbruik hoog tarief (DSMR v4.0)
      if (sscanf(buffer,"1-0:2.8.2(%ld.%ld" ,&tl, &tld)==2){
//      Serial.println("TmEVHT gevonden");
        tl *= 1000;
        tl += tld;
        TmEVHT = tl;
//    Serial.print("TmEVHT Zonnepaneel Hoog tarief: ");
//    Serial.print(TmEVHT);
      // 1-0:1.7.0 = Electricity consumption actual usage (DSMR v4.0)
      if (sscanf(buffer,"1-0:1.7.0(%ld.%ld" ,&tl , &tld) == 2){
 //             Serial.println("mEAV gevonden");
        mEAV = (tl*1000)+tld;
//   Serial.print("mEAV Actueel : ");
//   Serial.print(mEAV);
      // 1-0:2.7.0 = Electricity consumption actual usage (DSMR v4.0)
      if (sscanf(buffer,"1-0:2.7.0(%ld.%ld" ,&tl , &tld) == 2){
        TmEAV = (tl*1000)+tld;
//    Serial.print("TmEAV Zonnepaneel Actueel : ");
//    Serial.print(TmEAV);
      // 0-1:24.2.1 = Gas (DSMR v4.0) on Kaifa MA105 meter
      if (strncmp(buffer, "0-1:24.2.1", strlen("0-1:24.2.1")) == 0) {
        if (sscanf(strrchr(buffer, '(') + 1, "%d.%d", &tl, &tld) == 2) {
//      Serial.println("mG gevonden");
        mG = (tl*1000)+tld;
//    Serial.print("Gas : ");
//    Serial.print(mG);
//    Serial.println(" m2");
      // Empty buffer again (whole array)
      for (int i=0; i<75; i++)
        buffer[i] = 0;
      bufpos = 0;
  } //Einde 'if AltSerial.available'
//  httpRequest();
} //Einde 'decodeTelegram()' functie
void httpRequest() {
  Serial.println("Send Request to RPi");
  // if there's a successful connection:
  if (client.connect(server, 80)) {
    client.print("GET /get.php?mEVLT=");
    client.print(PmEVLT);
    client.print("&mEVHT=");
    client.print(PmEVHT);
    client.print("&TmEVLT=");
    client.print(PTmEVLT);
    client.print("&TmEVHT=");
    client.print(PTmEVHT);
    client.print("&mEAV=");
    client.print(PmEAV);
    client.print("&TmEAV=");
    client.print(PTmEAV);
    client.print("&gas=");
    client.print(PmG);
    client.println(" HTTP/1.1");
    client.println("Host: 192.168.254.11");
    client.println("User-Agent: arduino-ethernet");
    client.println("Connection: close");
    client.println();
    //Request complete; empty recieve buffer
    while (client.available()) { //data available
      char c = client.read(); //gets byte from ethernet buffer
    client.println();
  else {
    client.stop();
