Arduino uno port selection problem
Hi guys, I have an Arduino Uno chip that I ordered from Amazon. When I connected it to my device so that I could program it, everything was fine, but what happened after I unplugged the Arduino Uno and connected it again to the device, I could not determine the port because it was visible in grey, even though the LED chip was working fine, I tried to download the CH340 Driver but that didn't work Also, I tried to connect it to another device with the Arduino IDE application, but unfortunately all this did not work.
[https://www.amazon.sa/-/en/gp/product/B07NDZVKV3/ref=ppx_yo_dt_b_asin_image_o01_s00?ie=UTF8&psc=1]
Did you have this problem before, or does the Arduino chip have a problem or a malfunction?
NOTE:
my pc system is windows 10 and also another PC is windows 10 , and both are HP+ The last time I uploaded the code to an Arduino Uno chip, its USB port overheated.
Did you re-boot your PC?
What is this mystery "device"?
Yes ,but still it doesn`t work
Did you connect any external hardware to the Arduino?
I tried to connect the ESP shield on Arduino Uno, but still, it doesn't work!
Before, or after it failed? Did you try it without any shield?
So far you've mentioned a custom IC, an UNO, and an ESP shield. I think it's time you showed with a diagram, how you have those connected...
After, at first I tried to connect it to the personal computer alone, then I tried to connect it to the computer and on top of it connect the ESP chip and both methods didn`t work for me.
Please read the forum instructions on how to ask a question.
I am having the same problem. A com port doesn't show up for my Arduino. On windows 10.
