Arduino UNO power consumption error
Hell guys I am having trouble solving this error , mby I am just stupid or what but here is the code :
#include <LiquidCrystal.h>
double sensePinV = 220;
double sensePinI = 0;
int timer;
int timerSec1;
int timerSec2;
int timerMin;
double Volts;
double Current;
double Power;
double PowerWh;
LiquidCrystal lcd(12, 11, 10, 5, 4, 3, 2);
void setup(){
  analogReference(DEFAULT);
  lcd.begin(16, 2);
  timer=0;
  Volts=0;
  Current=0;
  Power=0;
  PowerWh=0;
  Volts = 220;
  Current = (((analogRead(sensePinI)) / 212.0) - 2.55 / 0.06666667;
  if(Current < 0){
    Current = 0;
  Power = Volts * Current;
  PowerWh = (Power/3600) + PowerWh;
  lcd.setCursor(0,0);
  lcd.print("               ");
  lcd.setCursor(0,0);
  lcd.print(Volts);
  lcd.print("V");
  lcd.setCursor(10,0);
  lcd.print(Current);
  lcd.print("A");
  lcd.setCursor(0,1);
  lcd.print("               ");
  lcd.setCursor(0,1);
  lcd.print(Power);
  lcd.print("W");
  lcd.setCursor(10,1);
  lcd.print(PowerWh);
  lcd.print("Wh");
And the error i get is : exit status 1 : ‘Current’ does not name a type
Here is your loop function.
  Volts = 220;
Everything after this is misplaced code. All code belongs in functions, not spread wherever you feel like.
Are you sure that you posted the code that produces the error that you quote ? I get plenty of errors caused by what Paul points out but not the error that you seem to.
Thanks for the answer , so I get it right by putting all under void loop into the void loop?
You need to do that and see whether the result compiles, and, if it does, if it then does what you expect.
Doing so WILL resolve the error you asked about.
nvm idiot me
So guys now all is working but , when I go with experiment I get nothing displayed on lcd display
double sensePinIA0 = 0;
int timer;
int timerSec1;
int timerSec2;
int timerMin;
double Volts;
double Current;
double Power;
double PowerWh;
void setup(){
  lcd.begin(16, 2);
  timer=0;
  Volts=0;
  Current=0;
  Power=0;
  PowerWh=0;
  Volts = 220;
  Current = (((analogRead(sensePinIA0)) / 212.0) - (2.55 / 0.06666667));
  if(Current < 0){
    Current = 0;
  lcd.setCursor(0,0);
    lcd.print(Volts);
    lcd.print(" V ");
    lcd.print(Current);
    lcd.print(" A ");
So not really working after all. double sensePinIA0 = 0;Why a float for a pin number that will never change anyway so could be const byte ?
Does the LCD work with a simple "Hello World" program ?
Yes the program runs simple Hello World
steskaniarduino: Yes the program runs simple Hello World
So what is the difference between them in the definition and setup of the LCD ? Do you not even see "V" and "A" on the display ? What do you see if you use Serial.print() instead of lcd.print() ?
Your original code was
Your new code is
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
Spot the difference.
 amplitude_current = ((getMaxValue() / 212.0) - (2.55 / 0.06666667));
What are these "magic" numbers all about ?
