Hello, I bought the arduino uno starter kit SMD and would like to start my learning. However, after several days, it seems I unable to upload it to the board. I did identified it as clone the previous days and have installed the CH340v3.4 driver (tried the latest 3.8). My Arduino IDE is 1.8.8, I've tried using the latest 2.x Arduino IDE does not work either. I pressed the reset button on Arduino Uno boards and the light blink several times but still getting the same error as below. I did several forced upload but it still giving the same error. I've checked my port and board with the default programmer mode: AVRISP mkII. I've also tried using different cables but none of them work and giving the same error as below. Does anyone have recommendation for solution?
Error from console:
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\User\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
Using Port : COM7
Using Programmer : arduino
Overriding Baud Rate : 115200
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Hardware Version: 3
Firmware Version: 4.4
Vtarget : 0.3 V
Varef : 0.3 V
Oscillator : 28.800 kHz
SCK period : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "C:\Users\User\AppData\Local\Temp\arduino_build_349459/Blink.ino.hex"
avrdude: writing flash (924 bytes):
Writing | ######
avrdude: stk500_paged_write(): (a) protocol error, expect=0x14, resp=0x10
######avrdude: stk500_recv(): programmer is not responding
I can't stop it as it went in a loop. The only thing i can stop it is close the IDE or unplugged the board.
