Arduino uno programming over OTA with ESP8266
Itsch:
I dont can use the examples from WiFi link it dont verify, I can only use the examples from the beginner guide A Beginner's Guide to the ESP8266
i have the ip adress and with the AP sketch i cane connect with the ESP8266 but i dont have a Web-panel
the examples in Pieters guide are for esp8266. WiFilLink is for MCU which uses esp8266 as WiFi adapter
I must first load the ArduinoFirmwareESP to the Esp8266 and then connect the Esp8266 as shield to the uno and load the example sketch to the uno ? i have did that but nothing comes at the monitor
Itsch:
the example has Serial.begin(115200) and in Serial Monitor you have 9600 baud set.
yes but with 115200 its the same
Itsch:
upload the firmware with "Erase Flash" option set to "Sketch + WiFi Settings". the firmware then should start in AP mode
Still the same problem
Itsch:
so. Blink works, WiFi Scan works, WebClient example works, WiFiAccessPoint example works, AdvancedWebServer example works, but WiFiLink firmware doesn't work?
yes :confused:
so if you start the WiFiAccessPoint example you can find the AP in WiFi networks?
did you try to access the WiFiLink firmware web panel with the IP address printed by the WebClient example? it should get the same IP over DHCP
try the FSBrowser example with SPIFFS
yes the WiFiAcessPoint example works i have the AP and connection to the ip adress
the WebClient example is for a shild with Ethernet not with wifi ? i only can use the WiFi Client ?
what can i do with the FSBrowser eample ? i dont get a AP from this
Itsch:
yes WiFiClient or any other esp8266 example that prints the IP address assigned by the DHCP
make the FSBrowser example work.
I need the DHCP for FSBrowser ?
FSBrowser dosent work
Itsch:
did you upload SPIFFS data with the IDE plugin?
DHCP assigns IP addresses to devices. and the esp8266 should get the same IP address no matter what sketch it is running, (if the sketch doesn't use static IP address). so if you run one example with success and it prints the IP address, you will know it for the WiFiLink firmware (which doesn't print it)
the FSBrowser example should check if you can upload SPIFFS
Yes I Upload with SPIFFS but it don't work
That means SPIFFS Upload don't work ?
I don´t use an FTDI Adapter to connect with the ESP8266 i use the Arduino uno is this maybe a problem ?
Esp8266 Sketch Data Upload works, it runs to the 100%
but the sketches don,t work ?
or i need really v1.6 from the Arduino IDE ?
Itsch:
I never used IDE older then 1.8
so you have some problem with SPIFFS. WiFiLink can work without SPIFFS only you can't use Web Panel to set it up. then you should add WiFi.begin(SSID, PASSWORD); into examples of WiFiLink
when you try the WiFi Link library examples, did you reconfigure the Uno/esp8266 connection to SoftwareSerial with RX to TX wiring?
i dont have a WiFi.begin example, yes i use 6,7 and upload to the uno ?
Itsch:
char ssid[] = "xyz";            // your network SSID (name)
char pass[] = "abcd1234";        // your network password
int status = WL_IDLE_STATUS;     // the Wifi radio's status
  // initialize serial for debugging
  // initialize serial for ESP module
  Serial1.begin(9600);
  // initialize ESP module
  WiFi.init(&Serial1);
  // check for the presence of the shield
  if (WiFi.status() == WL_NO_SHIELD) {
    Serial.println("WiFi shield not present");
    // don't continue
    while (true);
  // attempt to connect to WiFi network
  while ( status != WL_CONNECTED) {
    Serial.print("Attempting to connect to WPA SSID: ");
    Serial.println(ssid);
    // Connect to WPA/WPA2 network
    status = WiFi.begin(ssid, pass);
  // you're connected now, so print out the data
  Serial.println("You're connected to the network");
  printWifiStatus();
copy in ArduinoFirmwareEsp ?
