Arduino UNO Programming Question
Hello,
Few days ago i just get an Arduino UNO, for a small project.
It's my first time when i use that board, i have no programming experience.
My project its like that:
I have one board Arduino UNO
One Moisture sensor
One 5v Relay for Arduino
And a LCD
5v Mini water pump
I find that code and i use it, it works
const int VAL_PROBE = 0; //Analog pin 0
const int MOISTURE_LEVEL = 250; // the value after the LED goes on
  pinMode(13, OUTPUT);
  pinMode(7, OUTPUT);
void LedState(int state)
  digitalWrite(13,state);
  int moisture = analogRead(VAL_PROBE);
  Serial.print("Moisture = ");
  Serial.println(moisture);
  if(moisture > MOISTURE_LEVEL)
    LedState(HIGH);
    digitalWrite(7,LOW);
    LedState(LOW);
    digitalWrite(7,HIGH);
But i want to use that LCD Display too, i really need a code to show:
Soil Moisture : %
Last Watered : Date/Time
I'm asking you guys because its something new for me, and i need that a bit fast.. i started since yesterday to learn Arduino by myself..
Thanks all.
Here you go:
Just replace lcd.print("Hello World") with
lcd.print("Soil Moisture: ");
        lcd.print(moisture);
and so on....
I'm using LCD with I2C adaptor, wires are GND VCC SCL SDA, i have to put on the same pins on arduino board too, that SCL SDA , i know gnd/vcc its for power.
Arduino has a dedicated library to allow you communicate with I2C devices :wink:
Get it, but i have no clue how to combine LCD with my sensor->relay code..
I change my code with
#include <Wire.h>
#include <LCD.h>
#define I2C_ADDR    0x27 // <<----- Add your address here.  Find it from I2C Scanner
#define BACKLIGHT_PIN     3
#define En_pin  2
#define Rw_pin  1
#define Rs_pin  0
#define D4_pin  4
#define D5_pin  5
#define D6_pin  6
#define D7_pin  7
int n = 1;
LiquidCrystal_I2C  lcd(I2C_ADDR,En_pin,Rw_pin,Rs_pin,D4_pin,D5_pin,D6_pin,D7_pin);
 int potPin = A0; //input pin
int soil=250;
  lcd.setBacklightPin(BACKLIGHT_PIN,POSITIVE);
lcd.setBacklight(HIGH);
lcd.home (); // go home
 lcd.begin(16, 2);
 // lcd rows and columns
 lcd.print("Humidity");
// title of sorts
// map the values
 int soil = analogRead(potPin) ;
 soil = constrain(soil, 485, 1023);
 soil = map(soil, 485, 1023, 100, 0);
 lcd.setCursor(0, 1);
 //display final numbers
 lcd.print(soil);
 //print the percent symbol at the end
 lcd.print("%");
//wait 0.1 seconds
 delay(75);
//wipe the extra characters
 lcd.print(" ");
 delay(1);
That works, sensor works and on lcd it show me, humidity
But my water pump relay its removed and i don't know how to put it and : Last watered message on LCD..
